Issue with SPF syntax
I am having issues receiving emails from a supplier of ours. The error is in the SPF lookup:
Tue 2024-01-09 06:59:42: Performing SPF lookup (lanhaiceramics.com / 183.56.219.201)Tue 2024-01-09 06:59:43: * Policy: v=spf1 include:corp.21cn.com. -allTue 2024-01-09 06:59:43: * Evaluating include:corp.21cn.com.: performing lookupTue 2024-01-09 06:59:43: * Evaluating include:corp.21cn.com.: no match; no SPF record in DNSTue 2024-01-09 06:59:43: * Evaluating -all: matchTue 2024-01-09 06:59:43: * Result: failTue 2024-01-09 06:59:43: ** Reject 550 183.56.219.201 is not allowed to send mail as lanhaiceramics.comNow, I think the error stems from the dot behind com:Policy: v=spf1 include:corp.21cn.com. -allOne of the reasons why I believe so is because I did a syntax check:Passed with Warnings
The policy is syntactically valid, but there are warnings—it may not work as you would expect.
- WARNING
The domain name for the "include" mechanism ends with a dot. Trailing dots should not be used, because they introduce ambiguity. Evaluation results may depend on the SPF client implementation.
Might this be the issue and if so, is there a work-around or a bug that can be fixed?Thank you very much!Best regards,Johan
- WARNING
