Multiple users using same account simultaneously
With business gmail - Google apps - we have the ability to have multiple people log in from different locations/devices simultaneously to one account - the scenario is sort of a help desk type situation where depending on who is requesting what the relevant tech can responsd and then as it's email other techs can follow and pickup/pipe into the thread if necessary. How would we do that in Mdaemon?
Thannks in advance for your attention to this.
There are a couple of ways you can do this. The one I think works best is to use a public folder with the option enabled for "Assign a unique ticketing number to messges" with a submission address set. With this enabled, when a user responds to a message in the public folder the response will be sent from the submission address that is configured for the public folder and a copy of the sent message will be saved in a sub folder of the public folder.
Hello I did setup such a ' shared ticketing' account, with a public folder and ticketing number
It's seem to work well.
Remark
Just for your information if a user from an other domain (xy@test.com) has access to the 'ticketing' public email folder (ticket@domain.com) and respond to an received email then the response 'from email' has not been changed to ticket@domain.com but was xy@test.com
Question
Is it possible to have an alias on the 'ticketing' public email folder submission email = ticket@domain.com and alias = sales@domain.com ? And when responding to an email, the from is changed acordingly to the received email/alias. Emails sent to ticket@domain.com are replied from ticket@domain.com and emails sent to sales@domain.com are replied from sales@domain.com.
I understand that an easy solution is to setup a second ticketing public folder, but having a single public folder would suit best our needs.
Thanks
Yes, in the limited amount of testing that I've done, you can, but it will require that you manually edit some files. I would reccomend that you test this thoroughly before implementing in a live environment.
I'm assuming you already have the public folder setup with ticket@domain.com configured as the submission address and its enabled for ticketing. Create an alias for sales@domain.com = ticket@domain.com. The easiest way is to edit the MDaemon\app\alias.dat file with your favorite text editor. I use Notepad++. The entry will look like the following:
Save the file.
Then edit MDaemon\app\cfsysrules.dat file. There are 3 rules for each public folder that is configured for ticketing (RuleTicketing-1-ticket, RuleTicketing-2-ticket, RuleTicketing-3-ticket). You'll need to create a set second set of rules for sales, and then make some additional changes. There are a lot of changes to make here so it is probably easiest to just copy what I have below, and replace the existing 3 rules. You'll have to change domain.com to your actual domain name in all of these rules.
[RuleTicketing-1-sales]
RuleName=SYSTEM - Modify FROM on outbound emails
Enable=Yes
ThisRuleCondition=all
ProcessQueue=BOTH
Condition01=SUBJECT|reg exp|AND|\{sales [A-Z0-9]{11}\}.*|
Condition02=X-MDaemon-Deliver-To|is not equal to|AND|ticket@domain.com|
Action01=header search and replace|"From","<.*@domain.com>","<sales@domain.com>","0,1"
Action02=remove header|"Reply-To", ""
Action03=copy to public folders|"ticket/Replied To"
Action04=skip rule|"1"
[RuleTicketing-1-ticket]
Enable=Yes
ProcessQueue=BOTH
Condition01=SUBJECT|reg exp|AND|\{ticket [A-Z0-9]{11}\}.*|
Action01=header search and replace|"From","<.*@domain.com>","<ticket@domain.com>","0,1"
[RuleTicketing-2-sales]
RuleName=SYSTEM - Redirect tagged inbound emails
Enable=Yes
ProcessQueue=LOCAL
Condition02=FROM|does not contain|AND|<sales@domain.com>|
Condition03=X-MDaemon-Deliver-To|contains|AND|@domain.com|
Action01=header search and replace|"X-MDaemon-Deliver-To",".*","ticket@domain.com","0,1"
Action02=header search and replace|"X-MDRcpt-To:",".*","sales@domain.com","0,1"
Action03=skip rule|"3"
[RuleTicketing-2-ticket]
Enable=Yes
ProcessQueue=LOCAL
Condition02=FROM|does not contain|AND|<ticket@domain.com>|
Action02=skip rule|"2"
[RuleTicketing-3-sales]
RuleName=SYSTEM - Tag inbound emails
Enable=Yes
ProcessQueue=LOCAL
Condition01=X-MDRcpt-To|is equal to|AND|sales@domain.com|
Action01=header search and replace|"Subject",".*","{Sales $GEN_GUID$} $0","0,1"
Action02=skip rule|"1"
[RuleTicketing-3-ticket]
Enable=Yes
ProcessQueue=LOCAL
Condition01=X-MDaemon-Deliver-To|is equal to|AND|ticket@domain.com|
Action01=header search and replace|"Subject",".*","{ticket $GEN_GUID$} $0","0,1"Save the file and then restart MDaemon.
