Users with Authenticator enabled | MDaemon Technologies Community Forum
  • Hello,
    Would there be a way to find all users with and without the authenticator enabled?
    Thank you.
  • If by "authenticator" you mean they have two factor authetntication enabled you can search the User.ini file in the MDaemon\Users\$DOMAIN$\$MailBox\WC directory for TwoFactorAuthEnabled=Yes
    The easiest way I found to do this was using the Find in Files feature of Notepad++. In the Find What field enter TwoFactorAuthEnabled=Yes, in the Filters field enter User.ini, in the Directory field enter the path to the MDaemon\Users directory.  Then click Find All.
