XMPP / ComAgent issues after upgrade to v26.5.0 | MDaemon Technologies Community Forum
  • I upgraded our test Mdaemon server to version 26.5.0 last weekend.  Immediately I noticed some issues.
    We use Mdaemon Instant Messenger / ComAgent on our desktops.  After the upgrade, the buddy list was emptied, all contacts in the list removed.  I manually added my contacts back to the list and that seemed to work, they stayed there once again.  This issue in particular is preventing me from deploying the upgrade to our production server.
    We have a persistent chat room on the server.  When a user joins the room, they get a popup message for each message in the room's history, similar to when a user comes online, they fill the right hand side of the screen.
    When a user disconnects from the room, the server sends a join message, not a disconnect message, resulting in two instances of that user name in the participants list.  If the user reconnects to the room, no message appears.  Then if that user disconnects again, a disconnect message is sent, and one instance is removed.
    I'm hoping someone can verify this behavior and offer a solution.
  • We’ve confirmed all three issues.
    Buddy list emptied after the upgrade
    On domains that don’t use automatic buddy-list syncing, the 26.5 database upgrade removes contacts between users on the same domain unless they were filed in a named group. This happens once, during the upgrade, which is why the contacts you re-added have stayed. It isn’t fixed in a released build yet.
    Before upgrading production, stop MDaemon and make a copy of XMPPServer\xmppdb.db. Turning on “Enable buddy list syncing” before upgrading avoids the empty lists, but it doesn’t keep your users’ own contacts. With syncing on, every user sees all IM users in the domain. If you later turn syncing off, the lists will be empty. Only use it if a list of the whole domain is what you want.
    Restoring the contacts (on your test server now, or on production after upgrading). The upgrade saved a copy of the database first, so the contacts can be put back:
    1. Download the SQLite command-line tools for Windows (“sqlite-tools-win-x64”) from https://sqlite.org/download.html and extract sqlite3.exe, for example to C:\Temp.
    2. In XMPPServer\backups (default C:\MDaemon\XMPPServer\backups), find the file named xmppdb-preschema<n>-<date>-<time>.bak from the day you upgraded. Please don’t copy this file over the live database: the upgrade step would run again and remove the contacts again.
    3. In Windows Services, stop MDaemon XMPP Server. Mail keeps running; instant messaging is unavailable until step 7.
    4. Make a safety copy of XMPPServer\xmppdb.db, plus xmppdb.db-wal and xmppdb.db-shm if they exist.
    5. Save the script below as C:\Temp\restore.sql, and change the path on the ATTACH line to your backup file.
    6. From a command prompt, run:
      C:\Temp\sqlite3.exe "C:\MDaemon\XMPPServer\xmppdb.db" < C:\Temp\restore.sql
      It prints how many contacts it’s restoring, then restores them. It’s safe to run again; a second run adds nothing.
    7. Start MDaemon XMPP Server again. Users see their contacts the next time MDaemon Instant Messenger signs in.
    ATTACH DATABASE 'C:\MDaemon\XMPPServer\backups\xmppdb-preschema3-YYYYMMDD-HHMMSS.bak' AS bak;
    SELECT COUNT(*) AS contacts_to_restore
    FROM bak.RosterList r
    JOIN bak.Users bu1 ON bu1.UserID = r.UserID
    JOIN bak.Users bu2 ON bu2.UserID = r.RosterUserID
    JOIN main.Users lu1 ON lu1.Email = bu1.Email
    JOIN main.Users lu2 ON lu2.Email = bu2.Email
    WHERE LOWER(SUBSTR(bu1.Email, INSTR(bu1.Email, '@') + 1)) = LOWER(SUBSTR(bu2.Email, INSTR(bu2.Email, '@') + 1))
      AND r.SubscribeStatus = 'both'
      AND r.RosterListID NOT IN (SELECT RosterListID FROM bak.RosterGroupList)
      AND NOT EXISTS (SELECT 1 FROM main.RosterList m WHERE m.UserID = lu1.UserID AND m.RosterUserID = lu2.UserID);
    BEGIN;
    INSERT OR IGNORE INTO main.RosterList (UserID, RosterUserID, SubscribeStatus, AskStatus)
    SELECT lu1.UserID, lu2.UserID, r.SubscribeStatus, r.AskStatus
      AND r.RosterListID NOT IN (SELECT RosterListID FROM bak.RosterGroupList);
    COMMIT;
    DETACH DATABASE bak;
    What to expect from the restore:
    • Contacts removed on purpose since the upgrade come back. If someone deliberately removed a contact after upgrading, the restore can’t tell that apart from the upgrade’s removal, so that contact reappears and has to be removed again.
    • Contacts re-added since the upgrade are kept as they are, with no duplicates.
    • Accounts deleted since the upgrade are skipped, and accounts created since aren’t affected.
    • Only contact lists change. The script adds the missing contacts back into the current database instead of replacing it. Chat history, chat rooms and anything else changed since the upgrade are kept.
    • Restored contacts come back as approved contacts on both sides, as they were before the upgrade.
    • Instant messaging is unavailable while the XMPP service is stopped, usually a few minutes. Users may need to sign back in to MDaemon Instant Messenger.
    • To undo the restore, stop the XMPP service again and put back the safety copy from step 4.
    We recommend running the restore on your test server first and checking a few users’ lists before doing production.
    Popups for the room’s history when joining a room
    This is a known issue in MDaemon Instant Messenger. A bug has been logged for the development team to review.
    Leaving a room shows a join and lists the user twice
    We reproduced this and logged it as a server bug. It also happens when a user’s connection drops. It’s cosmetic: the extra entry disappears when that user next leaves the room, or when the room window is closed and reopened.
