ActiveSync wipeaccount and wipeclient | MDaemon Technologies Community Forum
  • Hi,
    I'm reviewing the documentation and doing some testing and I would confirm that it works correctly.
    When I do the wipeaccount
    <?xml version="1.0" encoding="utf-8"?>
    <MDaemon>
     <API productversion="22.5.0" serviceversion="22.5.0.1">
      <Request version="22.5" echo="1" verbose="0">
       <Operation>ActiveSync</Operation>
       <Parameters>
        <Client action="update" account="jmeilan@commcenter.es" clientid="E9F720EE2D5EE58202794E5F" wipeaccount="Yes" >
        </Client>
       </Parameters>
      </Request>
     </API>
    </MDaemon>
    With the following xml, it does it correctly, it deletes the account and the emails from the device.
    If I configure the email account again, it is automatically deleted from the device.
    Is this operation correct?
    I guess it creates a directive applied to the account and the client id.
    If this were so, any way to see the active directives of the server?
    and
    the wipeclient work?
    <MDaemon>
       <Parameters>
        <Client action="update" account="jmeilan@commcenter.es" clientid="E9F720EE2D5EE58202794E5F" wipeclient="Yes" >
        </Client>
       </Parameters>
      </Request>
     </API>
    </MDaemon>
    Would I have to format the mobile device?
  • Yes, that behavior is correct. This prevents hostile actors from re-creating the device setup and gaining access to the server.
    To re-create the account on the client, you must first remove the client record from MDaemon and it must be removed it from the Blocked Clients list.
