I Can't Add Web Reference on c# on Visual Studio ?
Hi Everybody ,
I Connect XML Api Service On Web Browser and My Username and Password.
But When I Add Web Reference On C# My Username and passwod Not Working (XML Api Services Return 401 Error Code ) and I Can not adding web reference.
anyone know solution this problem.
Please help Me ?
Keith Staff
You code is somehow not sending a properly formatted authentication header in the http request.
What warning does it show in the MdMgmtWS logfine when you attempt this?
VS Studio Can not add web reference or can not read $metada File
MdMgmWS Logs records
23/05/31 00:00:04.898 General 00000000 Management Web Service (64bit) for MDaemon Messaging Server 23.0.1.2 Log file starting
23/05/31 00:00:04.898 General 00000000 0x41350011 0x00000009
23/05/31 00:00:04.898 General 00000000 0x41350010 D:\MDaemon\Data\MgmtWS.ini
23/05/31 09:23:12.539 Info 0000EE63 0x41330080 Connection: IPA:10.0.1.126 Server:ms01 Meth:GET SSL:On UA:Mozilla/4.0 (compatible; MSIE 6.0; MS Web Services Client Protocol 4.0.30319.42000) QS: Lang:(null) CT= CL=0
23/05/31 09:23:12.539 Warning 0000EE63 0x81420060 HTTP Status: 401
23/05/31 09:23:12.540 Info 0000EE63 0x41420030 Connection terminating
23/05/31 09:23:12.543 Info 0000EE6D 0x41330080 Connection: IPA:10.0.1.126 Server:ms01 Meth:GET SSL:On UA:Mozilla/4.0 (compatible; MSIE 6.0; MS Web Services Client Protocol 4.0.30319.42000) QS: Lang:(null) CT= CL=0
23/05/31 09:23:12.543 Warning 0000EE6D 0x81420060 HTTP Status: 401
23/05/31 09:23:12.543 Info 0000EE6D 0x41420030 Connection terminating
23/05/31 09:23:12.905 Info 0000EE69 0x41330080 Connection: IPA:10.0.1.126 Server:ms01 Meth:POST SSL:On UA:(null) QS: Lang:(null) CT=application/soap+xml; charset=utf-8 CL=467
23/05/31 09:23:12.905 Warning 0000EE69 0x81420060 HTTP Status: 401
23/05/31 09:23:12.905 Info 0000EE69 0x41420030 Connection terminating
23/05/31 09:23:12.906 Info 0000EE5F 0x41330080 Connection: IPA:10.0.1.126 Server:ms01 Meth:POST SSL:On UA:(null) QS: Lang:(null) CT=application/soap+xml; charset=utf-8 CL=471
23/05/31 09:23:12.906 Warning 0000EE5F 0x81420060 HTTP Status: 401
23/05/31 09:23:12.906 Info 0000EE5F 0x41420030 Connection terminating
23/05/31 09:23:24.583 Info 0000EE77 0x41330080 Connection: IPA:10.0.1.126 Server:ms01 Meth:GET SSL:On UA:Mozilla/4.0 (compatible; MSIE 6.0; MS Web Services Client Protocol 4.0.30319.42000) QS: Lang:(null) CT= CL=0
23/05/31 09:23:24.583 Warning 0000EE77 0x81420060 HTTP Status: 401
23/05/31 09:23:24.584 Info 0000EE77 0x41420030 Connection terminating
23/05/31 09:23:24.625 Info 0000EE7D 0x41330080 Connection: IPA:10.0.1.126 Server:ms01 Meth:GET SSL:On UA:Mozilla/4.0 (compatible; MSIE 6.0; MS Web Services Client Protocol 4.0.30319.42000) QS: Lang:(null) CT= CL=0
23/05/31 09:23:24.777 Info 0000EE7D 0x41330006 Logon Attempt: mehmet.yenilmez@bashan.com.tr
23/05/31 09:23:24.777 Warning 0000EE7D 0x81420060 HTTP Status: 401
23/05/31 09:23:24.777 Info 0000EE7D 0x41420030 Connection terminating
23/05/31 09:24:34.034 Info 0000EE84 0x41330080 Connection: IPA:10.0.1.126 Server:ms01 Meth:GET SSL:On UA:Mozilla/4.0 (compatible; MSIE 6.0; MS Web Services Client Protocol 4.0.30319.42000) QS: Lang:(null) CT= CL=0
23/05/31 09:24:34.034 Warning 0000EE84 0x81420060 HTTP Status: 401
23/05/31 09:24:34.034 Info 0000EE84 0x41420030 Connection terminating
23/05/31 09:24:34.036 Info 0000EE8A 0x41330080 Connection: IPA:10.0.1.126 Server:ms01 Meth:GET SSL:On UA:Mozilla/4.0 (compatible; MSIE 6.0; MS Web Services Client Protocol 4.0.30319.42000) QS: Lang:(null) CT= CL=0
23/05/31 09:24:34.037 Warning 0000EE8A 0x81420060 HTTP Status: 401
23/05/31 09:24:34.037 Info 0000EE8A 0x41420030 Connection terminating
23/05/31 09:24:34.405 Info 0000EE94 0x41330080 Connection: IPA:10.0.1.126 Server:ms01 Meth:POST SSL:On UA:(null) QS: Lang:(null) CT=application/soap+xml; charset=utf-8 CL=471
23/05/31 09:24:34.405 Warning 0000EE94 0x81420060 HTTP Status: 401
23/05/31 09:24:34.405 Info 0000EE94 0x41420030 Connection terminating
23/05/31 09:24:34.405 Info 0000EE90 0x41330080 Connection: IPA:10.0.1.126 Server:ms01 Meth:POST SSL:On UA:(null) QS: Lang:(null) CT=application/soap+xml; charset=utf-8 CL=467
23/05/31 09:24:34.406 Warning 0000EE90 0x81420060 HTTP Status: 401
23/05/31 09:24:34.406 Info 0000EE90 0x41420030 Connection terminating
23/05/31 09:24:48.815 Info 0000EE9C 0x41330080 Connection: IPA:10.0.1.126 Server:ms01 Meth:GET SSL:On UA:Mozilla/4.0 (compatible; MSIE 6.0; MS Web Services Client Protocol 4.0.30319.42000) QS: Lang:(null) CT= CL=0
23/05/31 09:24:48.815 Warning 0000EE9C 0x81420060 HTTP Status: 401
23/05/31 09:24:48.815 Info 0000EE9C 0x41420030 Connection terminating
Keith Staff
I am not familiar with adding a "Web Reference", however, the XMLAPI uses Basic authentication, always.
First, unrelated to the 401 you are receiving, is that the content-type header on any post operations should be set to text/xml, not application/soap+xml
Regarding the 401, all POST and GET requests require a properly formatted Basic Authentication header. There could be a number of possible issues with your request...
- You might not be sending an Authorization Header with Basic and a properly base64 encoded logon and password
- You might be sending an Authorization Header but the authentication type is not set to Basic
- You might be sending an Authorization Header with Basic and the logon and password are not properly Base64 encoded or not present
- You might be sending an Authorization Header with Basic and the encoded auth information does not contain a colon ":" to separate the logon and password.
- You might be sending an Authorization Header with Basic and encoded auth information has no characters prior to the first colon character, hance, it has an empty logon name.
- You might be sending an Authorization Header with Basic and encoded auth information there are no characters following the first colon character, hence, an empty password value.
- The logon name specified does not include a domain and your MD settings require that you use the full email address for logons.
- You might be attempting to log on with an alias, and your MD settings do not allow that.
- The domain that you are using in your logon is disabled
Have you inspected the Authorization header that your client is sending?
Dear Keith ,
I Try SoapUi And I Send Basic Auth. And I Give Error
Error Message:
Error : WSDLException (at /MDaemon): faultCode=INVALID_WSDL: Expected element '{http://schemas.xmlsoap.org/wsdl/}definitions'
I try Many Difrent program to connect web XML Api But Result is all negative.
Can you share if you have any running programs and settings?
Keith Staff
The Samples in the Help portal (via web browser) list Powershell and Windows Script (JavaScript) files that contain functional code.
- DSAddBlackItem.wsf
- DSWhiteListReport.wsf
- FolderOperationGetContacts.wsf
- FolderOperation_create_delete.wsf
- GetDomainList.wsf
- Common.js
- ActiveSyncAlterLogEntries.ps1
- ActiveSyncDisable.ps1
- ActiveSyncEnable.ps1
- ActiveSyncGetClients.ps1
- ActiveSyncGetConfiguration.ps1
- ActiveSyncGetDomain.ps1
- ActiveSyncGetGlobal.ps1
- ActiveSyncSetLogLevelDebug.ps1
- ActiveSyncSetProcessDump.ps1
- CreateUserSample.ps1
- DSWhiteListReport.ps1
- GetVersionInfo.ps1
Hi Keith , I Know This Samples its Working.
But I Need Use This XML Api .Net Framework Project or .NET Core Project
This XML Api is not useable For VS And SoapUI .
VS and SoapUI Can Not Read Definitions and MetaData
Can This Api working Restful Mode ?
Keith Staff
There is currently no support for WSDL. At this time, none is planned, though we may consider it in the future.
I've written several WIN32 utilities in C++ that call the XMLAPI using the WinHttp API (native Win32, not .Net) and not having a WSDL does not preclude one from calling the API in C#, it merely means that you can't depend on Visual Studio to generate code for you.
Hello, let's see if I can provide some clarity. I have it working in C#. The issue is that you have to create the classes to deserialize the information. If you are familiar with the C# language, here is a function to test the XML.
I had a similar problem in my early stages with the API, and I have resolved it. I'm sharing the code snippet with you so that you can analyze it.
var httpClient = new HttpClient();
var byteArray = new UTF8Encoding().GetBytes($"{configuracion.adminEmail}:{configuracion.adminPassword}");
httpClient.DefaultRequestHeaders.Authorization = new AuthenticationHeaderValue("Basic", Convert.ToBase64String(byteArray));
var productValue = new ProductInfoHeaderValue("CommTool", "1.0");
httpClient.DefaultRequestHeaders.UserAgent.Add(productValue);
var stringContent = new StringContent(xmlText, Encoding.UTF8, "application/xml");
var xml = new StringContent(xmlText, Encoding.UTF8, "text/xml");
var respone = await httpClient.PostAsync($"{configuracion.url}", xml);
var test = respone.StatusCode;
var contents = await respone.Content.ReadAsStringAsync();if (respone.StatusCode == HttpStatusCode.OK)
XmlDocument xdoc = new XmlDocument();
xdoc.LoadXml(contents);response(doc: xdoc);
XmlNodeList elemList = xdoc.GetElementsByTagName("Record");
if (configuracion.Debug)
log.Debug($"--------------------- Ejecuntando el modulo: XMLTest --------------------------");
log.Debug($"{PrintXML(contents.ToString())}");
}return contents.ToString();
hope it helps you.
Hi Javier ,
Thank You For Helping , I Use This Code its Working Thank You.
Now it's Time to Create MDAEMON Objects from XML Files For C#
Have any Idea ?
Let's Go..
