Remote Admin Connection Problem
MDaemon 23.5 on Server 2022
I use a redirect to access remote admin, webadmin.domain.com which translates to mail.domain.com:444. Yesterday remote admin stopped working on the LAN and from outside the router. Remote adimin ports 444 and 1001 are listening on the server and I can access on the server itself via Chrome using webadmin.domain.com so the redirect is working properly. However, from any computer on the LAN I cannot connect. Here is a snippet from the WDaemon log:
Sun 2023-12-10 16:17:16.729: [389] Winsock accept error: 0.
Sun 2023-12-10 16:17:16.745: [390] Winsock accept error: 0.
Sun 2023-12-10 16:17:16.791: [391] Winsock accept error: -2146893007.
Sun 2023-12-10 16:17:16.883: [392] Winsock accept error: 0.
Sun 2023-12-10 16:17:16.885: [393] Winsock accept error: 0.
Sun 2023-12-10 16:17:16.948: [394] Winsock accept error: -2146893007.
Sun 2023-12-10 16:17:16.956: [395] Winsock accept error: -2146893007.
Sun 2023-12-10 16:22:13.563: [399] Winsock accept error: 10054.
Sun 2023-12-10 17:42:31.491: [416] Winsock accept error: 0.
Sun 2023-12-10 18:04:05.001: [479] Winsock accept error: 0.
Sun 2023-12-10 18:07:38.241: [507] Winsock accept error: -2146893017.
Sun 2023-12-10 18:07:40.378: [509] Winsock accept error: 10054.
Sun 2023-12-10 18:07:40.767: [510] Winsock accept error: 0.
Sun 2023-12-10 18:07:41.970: [511] Winsock accept error: 10054.
Sun 2023-12-10 18:07:42.436: [512] Winsock accept error: 10054.
Sun 2023-12-10 18:07:42.964: [513] Winsock accept error: 0.
Sun 2023-12-10 18:07:44.136: [514] Winsock accept error: 10054.
Sun 2023-12-10 18:07:44.332: [515] Winsock accept error: -2146893048.
Sun 2023-12-10 18:07:44.739: [516] Winsock accept error: -2146893048.
Sun 2023-12-10 18:07:45.243: [517] Winsock accept error: -2146893007.
Sun 2023-12-10 18:07:45.679: [518] Winsock accept error: -2146893048.
Sun 2023-12-10 18:14:32.802: [535] Winsock accept error: 0.
Sun 2023-12-10 18:14:33.160: [536] Winsock accept error: 0.
Sun 2023-12-10 18:14:33.509: [537] Winsock accept error: 0.
Sun 2023-12-10 18:14:33.875: [538] Winsock accept error: 0.
Sun 2023-12-10 18:14:34.232: [539] Winsock accept error: 0.
Sun 2023-12-10 18:14:34.596: [540] Winsock accept error: 0.
Sun 2023-12-10 18:14:34.771: [541] Winsock accept error: -2146893048.
Sun 2023-12-10 18:14:35.312: [542] Winsock accept error: 0.
Sun 2023-12-10 18:14:35.499: [543] Winsock accept error: -2146893007.
Sun 2023-12-10 18:14:36.036: [544] Winsock accept error: 0.
Sun 2023-12-10 18:14:36.220: [545] Winsock accept error: -2146893048.Any thoughts as to why this is happening?
Thanks,
Jay
Arron Staff
What are you using to do the redirecting? Is that device logging any errors?
When on the LAN, are you typically allowed to access https://mail.domain.com:444 or http://mail.domain.com:1001? Is it currenlty working?
If you run fiddler on one of the LAN machines and try to access http://webadmin.domain.com what does it show is happening?
For the HTTPS connections, can you confirm the certificates are still valid and that they support the host names you are connecting to?
I use Oracle Cloud Infrastructure for DNS and Redirection. Redirection is working for webmail.domain.com which redirects to https://mail.domain.com:443 , but webadmin.domain.com is not working. Even if I enter the redirection address manually, https://mail.domain.com:444 it does not work. I am not familiar with Fiddler but I will give it a try. As for certificates, Let's encrypt renewed the certificate just before this occurred, however, email accounts are working in Outlook as is Webmail.
@Arron
[Fiddler] The connection to 'mail.domain.com' failed. <br />Error: TimedOut (0x274c). <br />System.Net.Internals.SocketExceptionFactory+ExtendedSocketException A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. 173.x.x.x:444
@Arron I restored an image from two weeks ago just before the certificate update and re-ran Let's Encrypt update and now Webadmin works. Something must have gone wrong when I ran the Let's Encrypt update the first time. Thank you Arron for your time and the question that triggered the solution to the problem.
Arron Staff
I'm glad you got it working again.
