ClamAV pattern not updated
Hi,
I'm using MD 23.5.3 and ClamAV pattern not updated. (same issue previous version of MD).
[Mon 2024-03-18 13:36:24] ----- AVUpdater for MDaemon 23.5.3 Log file starting ---
[Mon 2024-03-18 13:36:26] ClamAV update process started at Mon Mar 18 13:36:26 2024
[Mon 2024-03-18 13:36:26] Mon Mar 18 13:36:26 2024 -> daily database available for update (local version: 26918, remote version: 27217)
[Mon 2024-03-18 13:36:26] Current database is 299 versions behind.
[Mon 2024-03-18 13:36:26] Downloading database patch # 26919...
[Mon 2024-03-18 13:36:33] WARNING: Mon Mar 18 13:36:33 2024 -> ******* RESULT 404, SIZE: 153 *******
[Mon 2024-03-18 13:36:33] WARNING: Mon Mar 18 13:36:33 2024 -> downloadFile: file not found: https://database.clamav.net/daily-26919.cdiff
[Mon 2024-03-18 13:36:33] WARNING: Mon Mar 18 13:36:33 2024 -> downloadPatch: Can't download daily-26919.cdiff from https://database.clamav.net/daily-26919.cdiff
[Mon 2024-03-18 13:36:33] Downloading database patch # 26919...
[Mon 2024-03-18 13:36:33] WARNING: Mon Mar 18 13:36:33 2024 -> Incremental update failed, trying to download daily.cvd
[Mon 2024-03-18 13:36:36] WARNING: Mon Mar 18 13:36:36 2024 -> ******* RESULT 200, SIZE: 63025170 *******
[Mon 2024-03-18 13:36:38] Testing database: 'D:\MDAEMON\SecurityPlus\ClamAVPlugin\data\tmp.f90557c3e8\clamav-ca4c4c2c381f189dd3a88cbb8b728d37.tmp-daily.cvd' ...
[Mon 2024-03-18 13:36:47] Database test passed.
[Mon 2024-03-18 13:36:47] Mon Mar 18 13:36:47 2024 -> daily.cvd updated (version: 27217, sigs: 2055524, f-level: 90, builder: raynman)
[Mon 2024-03-18 13:36:47] Mon Mar 18 13:36:47 2024 -> main.cvd database is up-to-date (version: 62, sigs: 6647427, f-level: 90, builder: sigmgr)
[Mon 2024-03-18 13:36:47] Mon Mar 18 13:36:47 2024 -> bytecode database available for update (local version: 334, remote version: 335)
[Mon 2024-03-18 13:36:47] Current database is 1 version behind.
[Mon 2024-03-18 13:36:47] Downloading database patch # 335...
[Mon 2024-03-18 13:36:47] WARNING: Mon Mar 18 13:36:47 2024 -> ******* RESULT 200, SIZE: 836 *******
[Mon 2024-03-18 13:36:48] Testing database: 'D:\MDAEMON\SecurityPlus\ClamAVPlugin\data\tmp.f90557c3e8\clamav-b84e9fde4d119f438eda0b0084651e2e.tmp-bytecode.cld' ...
[Mon 2024-03-18 13:36:48] Database test passed.
[Mon 2024-03-18 13:36:48] Mon Mar 18 13:36:48 2024 -> bytecode.cld updated (version: 335, sigs: 86, f-level: 90, builder: raynman)
[Mon 2024-03-18 13:36:49] ERROR: NotifyClamd: Can't connect to clamd on 127.0.0.1:3310: Connection refused
[Mon 2024-03-18 13:36:52] ----- AVUpdater for MDaemon 23.5.3 Log file stopping ---
