MDaemon 24.0.2 : problem with link | MDaemon Technologies Community Forum
  • Hello,
    since upgrading from MDaemon 24.0.1 to 24.0.2, we are experiencing problems with links that are dynamically generated and sent by email.
    On these links, “%27” has been added, rendering the link KO.
    No problems with these links via Outlook, %27 is only present in webmail.
    Thanks in advance.
    Best regards
  • This issue has been fixed in MDaemon 24.5.0, which is currently in beta.  We have created a patch for MDaemon 24.0.2 which can be downloaded from https://mdaemon.sharefile.com/public/share/web-s6cad1bdff28146a7a82958db734d6ead.
    To install the patch, go to the \MDaemon\WorldClient\HTML\All\JavaScript\ directory and make backups of the wc-utilities.js and wc-utilities.min.js files.  Then extract the same files from the download zip and place them in the directory.
    Once the new files are in place, restart webmail.
  • Hello Arron,
    thanks for the quick feedback, I've applied the patch and instructions but the problem still persists
  • Did you clear the browser caches?  If you did not, please try and if the problem persists, please provide a copy of an MSG file that has the issue.
    You can upload the file to https://mdaemon.sharefile.com/r-rc3922c1eed334d4dbf5e34f0bd04ccd6
  • Hello Arron,
    thank you, by clearing the browser cache I can confirm that the problem has been solved.
    Thanks a lot
