Hard drive upgrade | MDaemon Technologies Community Forum
Hard drive upgrade
  • we currently have hard drive that is dedicated for Mdaemon and was looking to upgrade it to a bigger drive.
    would there be any issues if we did a robocopy to a new drive and just change the drive letter?
    Looking for a safest way to upgrade the harddrives.
    Thank you.
  • Robocopy will work fine.  When moving the data with RoboCopy, you'll want to try to preserve timestamps on the files in mailboxes, especially if you are using POP3 to collect mail and leaving messages on the server.
    Our KB for moving MDaemon to a different path provides another way of doing it, https://knowledge.mdaemon.com/move-mdaemon-using-different-directory-path
  • Thank you so much for the quick reply. really appreciate it
