The CLam signatures stopped updating 9/30/2025
Can this be remedied on this current version?
ClamAV is no longer supporting or allowing version 103 to download updates to the database.
https://docs.clamav.net/faq/faq-eol.html
Yes, upgrading to a newer version of MDaemon will include a newer version of ClamAV.
If you don't want to upgade to a newer version of MDaemon, you can try manually downloading the database updates and putting them in place for ClamAV or manually downloading a newer version of ClamAV. Neither of these actions are supported by MDaemon Technologies.
Will it do an inplace upgrade?
I only have 4gb of ram on my server.
Its for home use.
Been using Mdaemon for 20 years at home.
Yes, you can install MDaemon 25.5 over MDaemon 21.5.6 and it will upgrade it in place. However, we no longer offer a 32 bit version of MDaemon and MDaemon 25.5 requires Windows 10/Server 2012 or newer. Depending on the operating system that you are currently using, you may need to upgrade the operating system first.
Im still running Windows 2012 Server.
the server has a 64 bit processor and 4gb of ram.
I basically have one email address.
Does this mean it will do an in place upgrade or a side by side?
It is going to do an in place upgrade.
