- Forum
- MDaemon Connector for Outlook
- Signatures and newly taken Users from AD
Hej there,
I'm not sure about, if it's a fault on my side or a bug within Outlook Connector.
we connected mDaemon to AD and configured mail signature within domain manager - client signatures. New users will be automatically drawn from a certain AD-group. Central Changes within signature will correctly be taken while restarting Outlook. So far, so fine...
If I put new users to that AD-Group and attach client no central signature will be taken, even after restarting outlook. You explicitly have to perform a manual "perform full Active Directory scan now", then signature will be taken upon next restart of Outlook.
By the way, we're completely new to mDaemon and are about to migrate from Exchange 2019 on prem to mDaemon.
regards,
Karsten
10
Posts534
Views
What version of MDaemon are you using?
What version of MDaemon Connector are you using?
What version of Outlook are you using?
When adding a new user to the AD group, does the account already exist in MDaemon? Or is adding the account to the AD group what causes the account to be created in MDaemon?
If adding the account to the AD group is what causes the account to be created in MDaemon, is the account actually created?
Is the account created on the correct domain in MDaemon?
After the account is created, is there a signature created in the MDaemon\Users\domain.com\mailbox\WC directory? There should be a signature-system.html.txt and a signature-system.txt.
If you login to Webmail after the account is created, is the domain signature available from the Signatures drop down under Options / Compose in the Edit Signatures section?
Are there any error in the MDaemon Connector log file when the user connects the first time? Can you post the session that shows the user connecting the first time?
Do you see an X-GWGETSETTINGS command being issued?
Arron Caruth
@Arron
Sorry, forgot...
- MDaemon - 25.5.1
- Connector - 8.0.2
- Outlook - 2019 Version 1808 - Build 10338.20019
- User doesn't exist in MDaemon - User will be created in MDaemon by adding to group
- User will be created in the correct domain. As we use two domains, I'm testing actually always with users from both.
- After adding newly created AD-user to desired AD-group the MDaemon User is directly being created, the ...\wc directory within MDaemon also, with user.ini. Mailbox configuration on client will be done, prepared server settings of MDaemon will be putted correctly in connector settings. First start of Outlook pulls further connector settings, wants restart of Outlook, will be done
Till now, no signature is being created in WC, neither any entry in drop down of Outlook. Just for staying precise, I configured signatures as client-signatures - an X-GWGETSETTINGS command is being issued, see:
Tue 2025-11-18 07:14:29.356: <-- 00000007 X-GWGETSETTINGS MDaemon signature
Tue 2025-11-18 07:14:29.363: --> * GWSETTINGS {19399}
Tue 2025-11-18 07:14:29.364: --> 00000007 OK X-GWGETSETTINGS completed- Log:
Tue 2025-11-18 07:11:50.603: Session 00011690; child 0005
Tue 2025-11-18 07:11:50.603: Accepting IMAP connection from 128.3.2.123:65434 to 128.3.2.85:993
Tue 2025-11-18 07:11:50.637: SSL-Protokollverhandlung erfolgreich (TLS 1.2, TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384)
Tue 2025-11-18 07:11:50.637: --> * OK maild.ehf-bau.de IMAP4rev1 ready
Tue 2025-11-18 07:11:50.638: <-- 00000000 CAPABILITY
Tue 2025-11-18 07:11:50.638: --> * CAPABILITY IMAP4rev1 NAMESPACE AUTH=LOGIN AUTH=PLAIN IDLE COMPRESS=DEFLATE ID ACL UNSELECT UIDPLUS QUOTA BINARY XLIST SASL-IR
Tue 2025-11-18 07:11:50.638: --> 00000000 OK CAPABILITY completed
Tue 2025-11-18 07:11:50.649: <-- 00000001 AUTHENTICATE PLAIN ******
Tue 2025-11-18 07:11:50.649: Echtheitsbestätigung für schulehf2@ehf-bau.de wird durchgeführt...
Tue 2025-11-18 07:11:50.666: Authenticated as schulehf2@ehf-bau.de
Tue 2025-11-18 07:11:50.704: --> 00000001 OK AUTHENTICATE completed
Tue 2025-11-18 07:11:50.705: <-- 00000002 CAPABILITY
Tue 2025-11-18 07:11:50.705: --> * CAPABILITY IMAP4rev1 NAMESPACE AUTH=LOGIN AUTH=PLAIN IDLE COMPRESS=DEFLATE ID ACL UNSELECT UIDPLUS QUOTA BINARY XLIST SASL-IR
Tue 2025-11-18 07:11:50.705: --> 00000002 OK CAPABILITY completed
Tue 2025-11-18 07:11:50.705: <-- 00000003 X-GWINIT 8.0.2
Tue 2025-11-18 07:11:50.706: --> 00000003 OK "8.0.2"
Tue 2025-11-18 07:11:50.706: <-- 00000004 COMPRESS DEFLATE
Tue 2025-11-18 07:11:50.706: --> 00000004 OK DEFLATE active
Tue 2025-11-18 07:11:50.707: <-- 00000005 NAMESPACE
Tue 2025-11-18 07:11:50.707: --> * NAMESPACE (("" "/")) (("Freigegebene Ordner/" "/")) (("&ANY-ffentliche Ordner/" "/"))
Tue 2025-11-18 07:11:50.707: --> 00000005 OK NAMESPACE completed
Tue 2025-11-18 07:11:50.708: <-- 00000006 GETQUOTA ""
Tue 2025-11-18 07:11:50.708: --> 00000006 NO GETQUOTA no such quota root
Tue 2025-11-18 07:11:50.708: <-- 00000007 X-GWGETSETTINGS 2001-01-01T00:00:00.000Z
Tue 2025-11-18 07:11:50.713: --> * GWSETTINGS {1658}
Tue 2025-11-18 07:11:50.713: --> 00000007 OK X-GWGETSETTINGS completed
Tue 2025-11-18 07:11:50.831: <-- 00000008 X-GWGETSETTINGS MDaemon password
Tue 2025-11-18 07:11:50.835: --> * GWSETTINGS {73}
Tue 2025-11-18 07:11:50.835: --> 00000008 OK X-GWGETSETTINGS completed
Tue 2025-11-18 07:11:50.836: <-- 00000009 LOGOUT
Tue 2025-11-18 07:11:50.836: --> * BYE IMAP engine signing off (no errors)
Tue 2025-11-18 07:11:50.836: --> 00000009 OK LOGOUT completed
Tue 2025-11-18 07:11:50.836: IMAP session complete, (Bytes in/out: 967/3214)
Tue 2025-11-18 07:11:50.836: ----------
Tue 2025-11-18 07:11:50.856: Session 00011693; child 0005
Tue 2025-11-18 07:11:50.856: Accepting IMAP connection from 128.3.2.123:65437 to 128.3.2.85:993
Tue 2025-11-18 07:11:50.893: SSL-Protokollverhandlung erfolgreich (TLS 1.2, TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384)
Tue 2025-11-18 07:11:50.893: --> * OK maild.ehf-bau.de IMAP4rev1 ready
Tue 2025-11-18 07:11:50.893: <-- 00000000 CAPABILITY
Tue 2025-11-18 07:11:50.893: --> * CAPABILITY IMAP4rev1 NAMESPACE AUTH=LOGIN AUTH=PLAIN IDLE COMPRESS=DEFLATE ID ACL UNSELECT UIDPLUS QUOTA BINARY XLIST SASL-IR
Tue 2025-11-18 07:11:50.893: --> 00000000 OK CAPABILITY completed
Tue 2025-11-18 07:11:50.904: <-- 00000001 AUTHENTICATE PLAIN ******
Tue 2025-11-18 07:11:50.904: Echtheitsbestätigung für SchulEHF2@ehf-bau.de wird durchgeführt...
Tue 2025-11-18 07:11:50.918: Authenticated as SchulEHF2@ehf-bau.de
Tue 2025-11-18 07:11:50.919: --> 00000001 OK AUTHENTICATE completed
Tue 2025-11-18 07:11:50.920: <-- 00000002 CAPABILITY
Tue 2025-11-18 07:11:50.920: --> * CAPABILITY IMAP4rev1 NAMESPACE AUTH=LOGIN AUTH=PLAIN IDLE COMPRESS=DEFLATE ID ACL UNSELECT UIDPLUS QUOTA BINARY XLIST SASL-IR
Tue 2025-11-18 07:11:50.920: --> 00000002 OK CAPABILITY completed
Tue 2025-11-18 07:11:50.921: <-- 00000003 X-GWINIT 8.0.2
Tue 2025-11-18 07:11:50.921: --> 00000003 OK "8.0.2"
Tue 2025-11-18 07:11:50.922: <-- 00000004 COMPRESS DEFLATE
Tue 2025-11-18 07:11:50.922: --> 00000004 OK DEFLATE active
Tue 2025-11-18 07:11:50.922: <-- 00000005 NAMESPACE
Tue 2025-11-18 07:11:50.922: --> * NAMESPACE (("" "/")) (("Freigegebene Ordner/" "/")) (("&ANY-ffentliche Ordner/" "/"))
Tue 2025-11-18 07:11:50.922: --> 00000005 OK NAMESPACE completed
Tue 2025-11-18 07:11:50.923: <-- 00000006 GETQUOTA ""
Tue 2025-11-18 07:11:50.923: --> 00000006 NO GETQUOTA no such quota root
Tue 2025-11-18 07:11:50.923: <-- 00000007 X-GWGETSETTINGS MDaemon password
Tue 2025-11-18 07:11:50.927: --> * GWSETTINGS {73}
Tue 2025-11-18 07:11:50.927: --> 00000007 OK X-GWGETSETTINGS completed
Tue 2025-11-18 07:11:50.927: <-- 00000008 LOGOUT
Tue 2025-11-18 07:11:50.927: --> * BYE IMAP engine signing off (no errors)
Tue 2025-11-18 07:11:50.927: --> 00000008 OK LOGOUT completed
Tue 2025-11-18 07:11:50.928: IMAP session complete, (Bytes in/out: 909/2570)
Tue 2025-11-18 07:11:50.928: ----------
Tue 2025-11-18 07:11:32.531: --> 00000042 OK MYRIGHTS completed
Tue 2025-11-18 07:11:32.533: <-- 00000043 NOOP
Tue 2025-11-18 07:11:32.533: --> 00000043 OK NOOP completed
Tue 2025-11-18 07:11:32.535: <-- 00000044 SELECT Kontakte
Tue 2025-11-18 07:11:32.535: --> * FLAGS (\Seen \Answered \Flagged \Deleted \Draft $Forwarded $MDNSent)
Tue 2025-11-18 07:11:32.535: --> * 0 EXISTS
Tue 2025-11-18 07:11:32.535: --> * 0 RECENT
Tue 2025-11-18 07:11:32.535: --> * OK [UIDVALIDITY 1763384659] UIDs valid
Tue 2025-11-18 07:11:32.535: --> * OK [UIDNEXT 1] Predicted next UID
Tue 2025-11-18 07:11:32.535: --> * OK [PERMANENTFLAGS (\Seen \Answered \Flagged \Deleted \Draft $Forwarded $MDNSent \*)] .
Tue 2025-11-18 07:11:32.535: --> 00000044 OK [READ-WRITE] SELECT completed
Tue 2025-11-18 07:11:32.535: <-- 00000045 GETQUOTA ""
Tue 2025-11-18 07:11:32.535: --> 00000045 NO GETQUOTA no such quota root
Tue 2025-11-18 07:11:32.537: <-- 00000046 MYRIGHTS Kontakte
Tue 2025-11-18 07:11:32.537: --> * MYRIGHTS "Kontakte" lrswipcda
Tue 2025-11-18 07:11:32.537: --> 00000046 OK MYRIGHTS completed
Tue 2025-11-18 07:11:32.542: <-- 00000047 NOOP
Tue 2025-11-18 07:11:32.542: --> 00000047 OK NOOP completed
Tue 2025-11-18 07:11:32.543: <-- 00000048 SELECT Notizen
Tue 2025-11-18 07:11:32.544: --> * FLAGS (\Seen \Answered \Flagged \Deleted \Draft $Forwarded $MDNSent)
Tue 2025-11-18 07:11:32.544: --> * 0 EXISTS
Tue 2025-11-18 07:11:32.544: --> * 0 RECENT
Tue 2025-11-18 07:11:32.544: --> * OK [UIDVALIDITY 1763384659] UIDs valid
Tue 2025-11-18 07:11:32.544: --> * OK [UIDNEXT 1] Predicted next UID
Tue 2025-11-18 07:11:32.544: --> * OK [PERMANENTFLAGS (\Seen \Answered \Flagged \Deleted \Draft $Forwarded $MDNSent \*)] .
Tue 2025-11-18 07:11:32.544: --> 00000048 OK [READ-WRITE] SELECT completed
Tue 2025-11-18 07:11:32.545: <-- 00000049 GETQUOTA ""
Tue 2025-11-18 07:11:32.545: --> 00000049 NO GETQUOTA no such quota root
Tue 2025-11-18 07:11:32.547: <-- 0000004a MYRIGHTS Notizen
Tue 2025-11-18 07:11:32.547: --> * MYRIGHTS "Notizen" lrswipcda
Tue 2025-11-18 07:11:32.547: --> 0000004a OK MYRIGHTS completed
Tue 2025-11-18 07:11:32.551: <-- 0000004b NOOP
Tue 2025-11-18 07:11:32.551: --> 0000004b OK NOOP completed
Tue 2025-11-18 07:11:32.552: <-- 0000004c SELECT Postausgang
Tue 2025-11-18 07:11:32.552: --> * FLAGS (\Seen \Answered \Flagged \Deleted \Draft $Forwarded $MDNSent)
Tue 2025-11-18 07:11:32.552: --> * 0 EXISTS
Tue 2025-11-18 07:11:32.552: --> * 0 RECENT
Tue 2025-11-18 07:11:32.552: --> * OK [UIDVALIDITY 1763384659] UIDs valid
Tue 2025-11-18 07:11:32.552: --> * OK [UIDNEXT 1] Predicted next UID
Tue 2025-11-18 07:11:32.552: --> * OK [PERMANENTFLAGS (\Seen \Answered \Flagged \Deleted \Draft $Forwarded $MDNSent \*)] .
Tue 2025-11-18 07:11:32.552: --> 0000004c OK [READ-WRITE] SELECT completed
Tue 2025-11-18 07:11:32.558: <-- 0000004d GETQUOTA ""
Tue 2025-11-18 07:11:32.558: --> 0000004d NO GETQUOTA no such quota root
Tue 2025-11-18 07:11:32.559: <-- 0000004e MYRIGHTS Postausgang
Tue 2025-11-18 07:11:32.559: --> * MYRIGHTS "Postausgang" lrswipcda
Tue 2025-11-18 07:11:32.559: --> 0000004e OK MYRIGHTS completed
Tue 2025-11-18 07:11:32.564: <-- 0000004f NOOP
Tue 2025-11-18 07:11:32.564: --> 0000004f OK NOOP completed
Tue 2025-11-18 07:11:32.565: <-- 00000050 SELECT RSS-Feeds
Tue 2025-11-18 07:11:32.565: --> * FLAGS (\Seen \Answered \Flagged \Deleted \Draft $Forwarded $MDNSent)
Tue 2025-11-18 07:11:32.565: --> * 0 EXISTS
Tue 2025-11-18 07:11:32.565: --> * 0 RECENT
Tue 2025-11-18 07:11:32.565: --> * OK [UIDVALIDITY 1763384659] UIDs valid
Tue 2025-11-18 07:11:32.565: --> * OK [UIDNEXT 1] Predicted next UID
Tue 2025-11-18 07:11:32.565: --> * OK [PERMANENTFLAGS (\Seen \Answered \Flagged \Deleted \Draft $Forwarded $MDNSent \*)] .
Tue 2025-11-18 07:11:32.565: --> 00000050 OK [READ-WRITE] SELECT completed
Tue 2025-11-18 07:11:32.566: <-- 00000051 GETQUOTA ""
Tue 2025-11-18 07:11:32.566: --> 00000051 NO GETQUOTA no such quota root
Tue 2025-11-18 07:11:32.567: <-- 00000052 MYRIGHTS RSS-Feeds
Tue 2025-11-18 07:11:32.567: --> * MYRIGHTS "RSS-Feeds" lrswipcda
Tue 2025-11-18 07:11:32.567: --> 00000052 OK MYRIGHTS completed
Tue 2025-11-18 07:12:51.242: <-- 00000053 X-GWGETSETTINGS 2025-11-13T14:01:18.658Z
Tue 2025-11-18 07:12:51.242: --> 00000053 OK X-GWGETSETTINGS completed
Tue 2025-11-18 07:12:51.246: <-- 00000054 NOOP
Tue 2025-11-18 07:12:51.246: --> 00000054 OK NOOP completed
Tue 2025-11-18 07:12:51.246: <-- 00000055 SELECT "&ANY-ffentliche Ordner"
Tue 2025-11-18 07:12:51.246: --> 00000055 NO Mailbox does not exist
Tue 2025-11-18 07:12:51.247: <-- 00000056 LOGOUT
Tue 2025-11-18 07:12:51.247: --> * BYE IMAP engine signing off (no errors)
Tue 2025-11-18 07:12:51.247: --> 00000056 OK LOGOUT completed
Tue 2025-11-18 07:12:51.247: IMAP session complete, (Bytes in/out: 4357/6482)further...
Tue 2025-11-18 07:14:35.498: Authenticated as SchulEHF2@ehf-bau.de
Tue 2025-11-18 07:14:35.499: --> 00000001 OK AUTHENTICATE completed
Tue 2025-11-18 07:14:35.500: <-- 00000002 CAPABILITY
Tue 2025-11-18 07:14:35.500: --> * CAPABILITY IMAP4rev1 NAMESPACE AUTH=LOGIN AUTH=PLAIN IDLE COMPRESS=DEFLATE ID ACL UNSELECT UIDPLUS QUOTA BINARY XLIST SASL-IR
Tue 2025-11-18 07:14:35.500: --> 00000002 OK CAPABILITY completed
Tue 2025-11-18 07:14:35.501: <-- 00000003 X-GWINIT 8.0.2
Tue 2025-11-18 07:14:35.501: --> 00000003 OK "8.0.2"
Tue 2025-11-18 07:14:35.501: <-- 00000004 COMPRESS DEFLATE
Tue 2025-11-18 07:14:35.501: --> 00000004 OK DEFLATE active
Tue 2025-11-18 07:14:35.502: <-- 00000005 SELECT "&ANY-ffentliche Ordner/ehf-bau.de"
Tue 2025-11-18 07:14:35.503: --> * FLAGS (\Seen \Answered \Flagged \Deleted \Draft $Forwarded $MDNSent)
Tue 2025-11-18 07:14:35.503: --> * 0 EXISTS
Tue 2025-11-18 07:14:35.503: --> * 0 RECENT
Tue 2025-11-18 07:14:35.503: --> * OK [UIDVALIDITY 1760453337] UIDs valid
Tue 2025-11-18 07:14:35.503: --> * OK [UIDNEXT 1] Predicted next UID
Tue 2025-11-18 07:14:35.503: --> * OK [PERMANENTFLAGS ()] No permanent flags permitted
Tue 2025-11-18 07:14:35.503: --> 00000005 OK [READ-ONLY] SELECT completed
Tue 2025-11-18 07:14:35.503: <-- 00000006 NAMESPACE
Tue 2025-11-18 07:14:35.503: --> * NAMESPACE (("" "/")) (("Freigegebene Ordner/" "/")) (("&ANY-ffentliche Ordner/" "/"))
Tue 2025-11-18 07:14:35.503: --> 00000006 OK NAMESPACE completed
Tue 2025-11-18 07:14:35.504: <-- 00000007 GETQUOTA ""
Tue 2025-11-18 07:14:35.504: --> 00000007 NO GETQUOTA no such quota root
Tue 2025-11-18 07:14:35.505: <-- 00000008 MYRIGHTS "&ANY-ffentliche Ordner/ehf-bau.de"
Tue 2025-11-18 07:14:35.505: --> * MYRIGHTS "&ANY-ffentliche Ordner/ehf-bau.de" lr
Tue 2025-11-18 07:14:35.505: --> 00000008 OK MYRIGHTS completed
Tue 2025-11-18 07:14:35.510: <-- 00000009 NOOP
Tue 2025-11-18 07:14:35.510: --> 00000009 OK NOOP completed
Tue 2025-11-18 07:14:35.511: <-- 0000000a SELECT "&ANY-ffentliche Ordner/ehf-bau.de/Kalender"
Tue 2025-11-18 07:14:35.512: --> * FLAGS (\Seen \Answered \Flagged \Deleted \Draft $Forwarded $MDNSent)
Tue 2025-11-18 07:14:35.512: --> * 0 EXISTS
Tue 2025-11-18 07:14:35.512: --> * 0 RECENT
Tue 2025-11-18 07:14:35.512: --> * OK [UIDVALIDITY 1762784016] UIDs valid
Tue 2025-11-18 07:14:35.512: --> * OK [UIDNEXT 1] Predicted next UID
Tue 2025-11-18 07:14:35.512: --> * OK [PERMANENTFLAGS ()] No permanent flags permitted
Tue 2025-11-18 07:14:35.512: --> 0000000a OK [READ-ONLY] SELECT completed
Tue 2025-11-18 07:14:35.512: <-- 0000000b GETQUOTA ""
Tue 2025-11-18 07:14:35.512: --> 0000000b NO GETQUOTA no such quota root
Tue 2025-11-18 07:14:35.514: <-- 0000000c MYRIGHTS "&ANY-ffentliche Ordner/ehf-bau.de/Kalender"
Tue 2025-11-18 07:14:35.514: --> * MYRIGHTS "&ANY-ffentliche Ordner/ehf-bau.de/Kalender" lr
Tue 2025-11-18 07:14:35.514: --> 0000000c OK MYRIGHTS completed
Tue 2025-11-18 07:14:35.519: <-- 0000000d NOOP
Tue 2025-11-18 07:14:35.519: --> 0000000d OK NOOP completed
Tue 2025-11-18 07:14:35.520: <-- 0000000e SELECT "&ANY-ffentliche Ordner/ehf-bau.de/Kontakte"
Tue 2025-11-18 07:14:35.521: --> * FLAGS (\Seen \Answered \Flagged \Deleted \Draft $Forwarded $MDNSent)
Tue 2025-11-18 07:14:35.521: --> * 12 EXISTS
Tue 2025-11-18 07:14:35.521: --> * 12 RECENT
Tue 2025-11-18 07:14:35.521: --> * OK [UNSEEN 1] first unseen
Tue 2025-11-18 07:14:35.521: --> * OK [UIDVALIDITY 1763014203] UIDs valid
Tue 2025-11-18 07:14:35.521: --> * OK [UIDNEXT 25] Predicted next UID
Tue 2025-11-18 07:14:35.521: --> * OK [PERMANENTFLAGS ()] No permanent flags permitted
Tue 2025-11-18 07:14:35.521: --> 0000000e OK [READ-ONLY] SELECT completed
Tue 2025-11-18 07:14:35.521: <-- 0000000f GETQUOTA ""
Tue 2025-11-18 07:14:35.521: --> 0000000f NO GETQUOTA no such quota root
Tue 2025-11-18 07:14:35.522: <-- 00000010 MYRIGHTS "&ANY-ffentliche Ordner/ehf-bau.de/Kontakte"
Tue 2025-11-18 07:14:35.522: --> * MYRIGHTS "&ANY-ffentliche Ordner/ehf-bau.de/Kontakte" lr
Tue 2025-11-18 07:14:35.522: --> 00000010 OK MYRIGHTS completed
Tue 2025-11-18 07:14:35.523: <-- 00000011 SEARCH UID 1:24 UNDELETED
Tue 2025-11-18 07:14:35.524: --> * SEARCH 1 2 3 4 5 6 7 8 9 10 11 12
Tue 2025-11-18 07:14:35.524: --> 00000011 OK SEARCH completed
Tue 2025-11-18 07:14:35.543: <-- 00000012 FETCH 1:12 (UID ENVELOPE BODY.PEEK[HEADER.FIELDS (X-Priority X-Message-Flag X-Message-Completed Sensitivity X-Message-Followup-Color)] BODYSTRUCTURE INTERNALDATE RFC822.SIZE FLAGS)
Tue 2025-11-18 07:14:35.543: Sending FETCH response (not logged)...
Tue 2025-11-18 07:14:35.662: --> 00000012 OK FETCH completed
Tue 2025-11-18 07:14:35.669: <-- 00000013 FETCH 12 BODY.PEEK[]
Tue 2025-11-18 07:14:35.669: Sending FETCH response (not logged)...
Tue 2025-11-18 07:14:35.669: --> 00000013 OK FETCH completed
Tue 2025-11-18 07:14:35.697: <-- 00000014 FETCH 11 BODY.PEEK[]
Tue 2025-11-18 07:14:35.697: Sending FETCH response (not logged)...
Tue 2025-11-18 07:14:35.697: --> 00000014 OK FETCH completed
Tue 2025-11-18 07:14:35.725: <-- 00000015 FETCH 10 BODY.PEEK[]
Tue 2025-11-18 07:14:35.725: Sending FETCH response (not logged)...
Tue 2025-11-18 07:14:35.725: --> 00000015 OK FETCH completed
Tue 2025-11-18 07:14:35.737: <-- 00000016 FETCH 9 BODY.PEEK[]
Tue 2025-11-18 07:14:35.737: Sending FETCH response (not logged)...
Tue 2025-11-18 07:14:35.737: --> 00000016 OK FETCH completed
Tue 2025-11-18 07:14:35.755: <-- 00000017 FETCH 8 BODY.PEEK[]
Tue 2025-11-18 07:14:35.755: Sending FETCH response (not logged)...
Tue 2025-11-18 07:14:35.756: --> 00000017 OK FETCH completed
Tue 2025-11-18 07:14:35.769: <-- 00000018 FETCH 7 BODY.PEEK[]
Tue 2025-11-18 07:14:35.769: Sending FETCH response (not logged)...
Tue 2025-11-18 07:14:35.770: --> 00000018 OK FETCH completed
Tue 2025-11-18 07:14:35.784: <-- 00000019 FETCH 6 BODY.PEEK[]
Tue 2025-11-18 07:14:35.784: Sending FETCH response (not logged)...
Tue 2025-11-18 07:14:35.784: --> 00000019 OK FETCH completed
Tue 2025-11-18 07:14:35.801: <-- 0000001a FETCH 5 BODY.PEEK[]
Tue 2025-11-18 07:14:35.801: Sending FETCH response (not logged)...
Tue 2025-11-18 07:14:35.801: --> 0000001a OK FETCH completed
Tue 2025-11-18 07:14:35.814: <-- 0000001b FETCH 4 BODY.PEEK[]
Tue 2025-11-18 07:14:35.814: Sending FETCH response (not logged)...
Tue 2025-11-18 07:14:35.815: --> 0000001b OK FETCH completed
Tue 2025-11-18 07:14:35.853: <-- 0000001c FETCH 3 BODY.PEEK[]
Tue 2025-11-18 07:14:35.853: Sending FETCH response (not logged)...
Tue 2025-11-18 07:14:35.854: --> 0000001c OK FETCH completed
Tue 2025-11-18 07:14:35.892: <-- 0000001d NOOP
Tue 2025-11-18 07:14:35.892: --> 0000001d OK NOOP completed
Tue 2025-11-18 07:14:35.893: <-- 0000001e SELECT Kontakte
Tue 2025-11-18 07:14:35.894: --> * FLAGS (\Seen \Answered \Flagged \Deleted \Draft $Forwarded $MDNSent)
Tue 2025-11-18 07:14:35.894: --> * 0 EXISTS
Tue 2025-11-18 07:14:35.894: --> * 0 RECENT
Tue 2025-11-18 07:14:35.894: --> * OK [UIDVALIDITY 1763446469] UIDs valid
Tue 2025-11-18 07:14:35.894: --> * OK [UIDNEXT 1] Predicted next UID
Tue 2025-11-18 07:14:35.894: --> * OK [PERMANENTFLAGS (\Seen \Answered \Flagged \Deleted \Draft $Forwarded $MDNSent \*)] .
Tue 2025-11-18 07:14:35.894: --> 0000001e OK [READ-WRITE] SELECT completed
Tue 2025-11-18 07:14:35.895: <-- 0000001f GETQUOTA ""
Tue 2025-11-18 07:14:35.895: --> 0000001f NO GETQUOTA no such quota root
Tue 2025-11-18 07:14:35.897: <-- 00000020 MYRIGHTS Kontakte
Tue 2025-11-18 07:14:35.897: --> * MYRIGHTS "Kontakte" lrswipcda
Tue 2025-11-18 07:14:35.897: --> 00000020 OK MYRIGHTS completed
Tue 2025-11-18 07:14:35.913: <-- 00000021 NOOP
Tue 2025-11-18 07:14:35.913: --> 00000021 OK NOOP completed
Tue 2025-11-18 07:14:35.914: <-- 00000022 SELECT "&ANY-ffentliche Ordner/ehf-bau.de/Kontakte"
Tue 2025-11-18 07:14:35.916: --> * FLAGS (\Seen \Answered \Flagged \Deleted \Draft $Forwarded $MDNSent)
Tue 2025-11-18 07:14:35.916: --> * 12 EXISTS
Tue 2025-11-18 07:14:35.916: --> * 12 RECENT
Tue 2025-11-18 07:14:35.916: --> * OK [UNSEEN 1] first unseen
Tue 2025-11-18 07:14:35.916: --> * OK [UIDVALIDITY 1763014203] UIDs valid
Tue 2025-11-18 07:14:35.916: --> * OK [UIDNEXT 25] Predicted next UID
Tue 2025-11-18 07:14:35.916: --> * OK [PERMANENTFLAGS ()] No permanent flags permitted
Tue 2025-11-18 07:14:35.916: --> 00000022 OK [READ-ONLY] SELECT completed
Tue 2025-11-18 07:14:35.917: <-- 00000023 GETQUOTA ""
Tue 2025-11-18 07:14:35.917: --> 00000023 NO GETQUOTA no such quota root
Tue 2025-11-18 07:14:35.927: <-- 00000024 MYRIGHTS "&ANY-ffentliche Ordner/ehf-bau.de/Kontakte"
Tue 2025-11-18 07:14:35.927: --> * MYRIGHTS "&ANY-ffentliche Ordner/ehf-bau.de/Kontakte" lr
Tue 2025-11-18 07:14:35.927: --> 00000024 OK MYRIGHTS completed
Tue 2025-11-18 07:14:35.928: <-- 00000025 UID FETCH 1:24 FLAGS
Tue 2025-11-18 07:14:35.928: Sending FETCH response (not logged)...
Tue 2025-11-18 07:14:35.928: --> 00000025 OK FETCH completed
Tue 2025-11-18 07:14:35.946: <-- 00000026 FETCH 1:2 (UID ENVELOPE BODY.PEEK[HEADER.FIELDS (X-Priority X-Message-Flag X-Message-Completed Sensitivity X-Message-Followup-Color)] BODYSTRUCTURE INTERNALDATE RFC822.SIZE FLAGS)
Tue 2025-11-18 07:14:35.946: Sending FETCH response (not logged)...
Tue 2025-11-18 07:14:35.947: --> 00000026 OK FETCH completed
Tue 2025-11-18 07:14:35.948: <-- 00000027 FETCH 2 BODY.PEEK[]
Tue 2025-11-18 07:14:35.948: Sending FETCH response (not logged)...
Tue 2025-11-18 07:14:35.948: --> 00000027 OK FETCH completed
Tue 2025-11-18 07:14:35.966: <-- 00000028 FETCH 1 BODY.PEEK[]
Tue 2025-11-18 07:14:35.966: Sending FETCH response (not logged)...
Tue 2025-11-18 07:14:35.967: --> 00000028 OK FETCH completed
Tue 2025-11-18 07:14:36.089: <-- 00000029 NOOP
Tue 2025-11-18 07:14:36.089: --> 00000029 OK NOOP completed
Tue 2025-11-18 07:14:36.090: <-- 0000002a SELECT "&ANY-ffentliche Ordner/hbg-pflasterbau.de"
Tue 2025-11-18 07:14:36.091: --> * FLAGS (\Seen \Answered \Flagged \Deleted \Draft $Forwarded $MDNSent)
Tue 2025-11-18 07:14:36.091: --> * 0 EXISTS
Tue 2025-11-18 07:14:36.091: --> * 0 RECENT
Tue 2025-11-18 07:14:36.091: --> * OK [UIDVALIDITY 1763043418] UIDs valid
Tue 2025-11-18 07:14:36.091: --> * OK [UIDNEXT 1] Predicted next UID
Tue 2025-11-18 07:14:36.091: --> * OK [PERMANENTFLAGS ()] No permanent flags permitted
Tue 2025-11-18 07:14:36.091: --> 0000002a OK [READ-ONLY] SELECT completed
Tue 2025-11-18 07:14:36.092: <-- 0000002b GETQUOTA ""
Tue 2025-11-18 07:14:36.092: --> 0000002b NO GETQUOTA no such quota root
Tue 2025-11-18 07:14:36.093: <-- 0000002c MYRIGHTS "&ANY-ffentliche Ordner/hbg-pflasterbau.de"
Tue 2025-11-18 07:14:36.093: --> * MYRIGHTS "&ANY-ffentliche Ordner/hbg-pflasterbau.de" lr
Tue 2025-11-18 07:14:36.093: --> 0000002c OK MYRIGHTS completed
Tue 2025-11-18 07:14:36.099: <-- 0000002d NOOP
Tue 2025-11-18 07:14:36.099: --> 0000002d OK NOOP completed
Tue 2025-11-18 07:14:36.099: <-- 0000002e SELECT "&ANY-ffentliche Ordner/hbg-pflasterbau.de/Kontakte"
Tue 2025-11-18 07:14:36.101: --> * FLAGS (\Seen \Answered \Flagged \Deleted \Draft $Forwarded $MDNSent)
Tue 2025-11-18 07:14:36.101: --> * 3 EXISTS
Tue 2025-11-18 07:14:36.101: --> * 3 RECENT
Tue 2025-11-18 07:14:36.101: --> * OK [UNSEEN 1] first unseen
Tue 2025-11-18 07:14:36.101: --> * OK [UIDVALIDITY 1763043418] UIDs valid
Tue 2025-11-18 07:14:36.101: --> * OK [UIDNEXT 9] Predicted next UID
Tue 2025-11-18 07:14:36.101: --> * OK [PERMANENTFLAGS ()] No permanent flags permitted
Tue 2025-11-18 07:14:36.101: --> 0000002e OK [READ-ONLY] SELECT completed
Tue 2025-11-18 07:14:36.102: <-- 0000002f GETQUOTA ""
Tue 2025-11-18 07:14:36.102: --> 0000002f NO GETQUOTA no such quota root
Tue 2025-11-18 07:14:36.104: <-- 00000030 MYRIGHTS "&ANY-ffentliche Ordner/hbg-pflasterbau.de/Kontakte"
Tue 2025-11-18 07:14:36.104: --> * MYRIGHTS "&ANY-ffentliche Ordner/hbg-pflasterbau.de/Kontakte" lr
Tue 2025-11-18 07:14:36.104: --> 00000030 OK MYRIGHTS completed
Tue 2025-11-18 07:14:36.104: <-- 00000031 SEARCH UID 1:8 UNDELETED
Tue 2025-11-18 07:14:36.104: --> * SEARCH 1 2 3
Tue 2025-11-18 07:14:36.104: --> 00000031 OK SEARCH completed
Tue 2025-11-18 07:14:36.121: <-- 00000032 FETCH 1:3 (UID ENVELOPE BODY.PEEK[HEADER.FIELDS (X-Priority X-Message-Flag X-Message-Completed Sensitivity X-Message-Followup-Color)] BODYSTRUCTURE INTERNALDATE RFC822.SIZE FLAGS)
Tue 2025-11-18 07:14:36.121: Sending FETCH response (not logged)...
Tue 2025-11-18 07:14:36.158: --> 00000032 OK FETCH completed
Tue 2025-11-18 07:14:36.161: <-- 00000033 FETCH 3 BODY.PEEK[]
Tue 2025-11-18 07:14:36.161: Sending FETCH response (not logged)...
Tue 2025-11-18 07:14:36.162: --> 00000033 OK FETCH completed
Tue 2025-11-18 07:14:36.178: <-- 00000034 FETCH 2 BODY.PEEK[]
Tue 2025-11-18 07:14:36.178: Sending FETCH response (not logged)...
Tue 2025-11-18 07:14:36.179: --> 00000034 OK FETCH completed
Tue 2025-11-18 07:14:36.192: <-- 00000035 FETCH 1 BODY.PEEK[]
Tue 2025-11-18 07:14:36.192: Sending FETCH response (not logged)...
Tue 2025-11-18 07:14:36.192: --> 00000035 OK FETCH completed
Tue 2025-11-18 07:14:36.215: <-- 00000036 NOOP
Tue 2025-11-18 07:14:36.215: --> 00000036 OK NOOP completed
Tue 2025-11-18 07:14:36.215: <-- 00000037 SELECT Aufgaben
Tue 2025-11-18 07:14:36.228: --> * FLAGS (\Seen \Answered \Flagged \Deleted \Draft $Forwarded $MDNSent)
Tue 2025-11-18 07:14:36.229: --> * 0 EXISTS
Tue 2025-11-18 07:14:36.229: --> * 0 RECENT
Tue 2025-11-18 07:14:36.229: --> * OK [UIDVALIDITY 1763446469] UIDs valid
Tue 2025-11-18 07:14:36.229: --> * OK [UIDNEXT 1] Predicted next UID
Tue 2025-11-18 07:14:36.229: --> * OK [PERMANENTFLAGS (\Seen \Answered \Flagged \Deleted \Draft $Forwarded $MDNSent \*)] .
Tue 2025-11-18 07:14:36.229: --> 00000037 OK [READ-WRITE] SELECT completed
Tue 2025-11-18 07:14:36.230: <-- 00000038 GETQUOTA ""
Tue 2025-11-18 07:14:36.230: --> 00000038 NO GETQUOTA no such quota root
Tue 2025-11-18 07:14:36.231: <-- 00000039 MYRIGHTS Aufgaben
Tue 2025-11-18 07:14:36.231: --> * MYRIGHTS "Aufgaben" lrswipcda
Tue 2025-11-18 07:14:36.231: --> 00000039 OK MYRIGHTS completed
Tue 2025-11-18 07:14:36.236: <-- 0000003a NOOP
Tue 2025-11-18 07:14:36.236: --> 0000003a OK NOOP completed
Tue 2025-11-18 07:14:36.236: <-- 0000003b SELECT "Einstellungen f&APw-r QuickSteps"
Tue 2025-11-18 07:14:36.237: --> * FLAGS (\Seen \Answered \Flagged \Deleted \Draft $Forwarded $MDNSent)
Tue 2025-11-18 07:14:36.237: --> * 0 EXISTS
Tue 2025-11-18 07:14:36.238: --> * 0 RECENT
Tue 2025-11-18 07:14:36.238: --> * OK [UIDVALIDITY 1763446469] UIDs valid
Tue 2025-11-18 07:14:36.238: --> * OK [UIDNEXT 1] Predicted next UID
Tue 2025-11-18 07:14:36.238: --> * OK [PERMANENTFLAGS (\Seen \Answered \Flagged \Deleted \Draft $Forwarded $MDNSent \*)] .
Tue 2025-11-18 07:14:36.238: --> 0000003b OK [READ-WRITE] SELECT completed
Tue 2025-11-18 07:14:36.238: <-- 0000003c GETQUOTA ""
Tue 2025-11-18 07:14:36.238: --> 0000003c NO GETQUOTA no such quota root
Tue 2025-11-18 07:14:36.239: <-- 0000003d MYRIGHTS "Einstellungen f&APw-r QuickSteps"
Tue 2025-11-18 07:14:36.239: --> * MYRIGHTS "Einstellungen f&APw-r QuickSteps" lrswipcda
Tue 2025-11-18 07:14:36.239: --> 0000003d OK MYRIGHTS completed
Tue 2025-11-18 07:14:36.246: <-- 0000003e NOOP
Tue 2025-11-18 07:14:36.246: --> 0000003e OK NOOP completed
Tue 2025-11-18 07:14:36.246: <-- 0000003f SELECT "Einstellungen f&APw-r Unterhaltungsaktionen"
Tue 2025-11-18 07:14:36.247: --> * FLAGS (\Seen \Answered \Flagged \Deleted \Draft $Forwarded $MDNSent)
Tue 2025-11-18 07:14:36.247: --> * 0 EXISTS
Tue 2025-11-18 07:14:36.247: --> * 0 RECENT
Tue 2025-11-18 07:14:36.247: --> * OK [UIDVALIDITY 1763446469] UIDs valid
Tue 2025-11-18 07:14:36.247: --> * OK [UIDNEXT 1] Predicted next UID
Tue 2025-11-18 07:14:36.247: --> * OK [PERMANENTFLAGS (\Seen \Answered \Flagged \Deleted \Draft $Forwarded $MDNSent \*)] .
Tue 2025-11-18 07:14:36.247: --> 0000003f OK [READ-WRITE] SELECT completed
Tue 2025-11-18 07:14:36.248: <-- 00000040 GETQUOTA ""
Tue 2025-11-18 07:14:36.248: --> 00000040 NO GETQUOTA no such quota root
Tue 2025-11-18 07:14:36.249: <-- 00000041 MYRIGHTS "Einstellungen f&APw-r Unterhaltungsaktionen"
Tue 2025-11-18 07:14:36.250: --> * MYRIGHTS "Einstellungen f&APw-r Unterhaltungsaktionen" lrswipcda
Tue 2025-11-18 07:14:36.250: --> 00000041 OK MYRIGHTS completed
Tue 2025-11-18 07:14:36.255: <-- 00000042 NOOP
Tue 2025-11-18 07:14:36.255: --> 00000042 OK NOOP completed
Tue 2025-11-18 07:14:36.256: <-- 00000043 SELECT Entw&APw-rfe
Tue 2025-11-18 07:14:36.256: --> * FLAGS (\Seen \Answered \Flagged \Deleted \Draft $Forwarded $MDNSent)
Tue 2025-11-18 07:14:36.256: --> * 0 EXISTS
Tue 2025-11-18 07:14:36.256: --> * 0 RECENT
Tue 2025-11-18 07:14:36.256: --> * OK [UIDVALIDITY 1763446469] UIDs valid
Tue 2025-11-18 07:14:36.256: --> * OK [UIDNEXT 1] Predicted next UID
Tue 2025-11-18 07:14:36.256: --> * OK [PERMANENTFLAGS (\Seen \Answered \Flagged \Deleted \Draft $Forwarded $MDNSent \*)] .
Tue 2025-11-18 07:14:36.256: --> 00000043 OK [READ-WRITE] SELECT completed
Tue 2025-11-18 07:14:36.257: <-- 00000044 GETQUOTA ""
Tue 2025-11-18 07:14:36.257: --> 00000044 NO GETQUOTA no such quota root
Tue 2025-11-18 07:14:36.258: <-- 00000045 MYRIGHTS Entw&APw-rfe
Tue 2025-11-18 07:14:36.258: --> * MYRIGHTS "Entw&APw-rfe" lrswipcda
Tue 2025-11-18 07:14:36.258: --> 00000045 OK MYRIGHTS completed
Tue 2025-11-18 07:14:36.264: <-- 00000046 NOOP
Tue 2025-11-18 07:14:36.264: --> 00000046 OK NOOP completed
Tue 2025-11-18 07:14:36.264: ---------- End partial transcript.
Tue 2025-11-18 07:14:06.464: --> 00000042 OK MYRIGHTS completed
Tue 2025-11-18 07:14:06.467: <-- 00000043 NOOP
Tue 2025-11-18 07:14:06.467: --> 00000043 OK NOOP completed
Tue 2025-11-18 07:14:06.473: <-- 00000044 SELECT Kontakte
Tue 2025-11-18 07:14:06.474: --> * FLAGS (\Seen \Answered \Flagged \Deleted \Draft $Forwarded $MDNSent)
Tue 2025-11-18 07:14:06.474: --> * 0 EXISTS
Tue 2025-11-18 07:14:06.474: --> * 0 RECENT
Tue 2025-11-18 07:14:06.474: --> * OK [UIDVALIDITY 1763384659] UIDs valid
Tue 2025-11-18 07:14:06.474: --> * OK [UIDNEXT 1] Predicted next UID
Tue 2025-11-18 07:14:06.474: --> * OK [PERMANENTFLAGS (\Seen \Answered \Flagged \Deleted \Draft $Forwarded $MDNSent \*)] .
Tue 2025-11-18 07:14:06.474: --> 00000044 OK [READ-WRITE] SELECT completed
Tue 2025-11-18 07:14:06.475: <-- 00000045 GETQUOTA ""
Tue 2025-11-18 07:14:06.475: --> 00000045 NO GETQUOTA no such quota root
Tue 2025-11-18 07:14:06.476: <-- 00000046 MYRIGHTS Kontakte
Tue 2025-11-18 07:14:06.476: --> * MYRIGHTS "Kontakte" lrswipcda
Tue 2025-11-18 07:14:06.476: --> 00000046 OK MYRIGHTS completed
Tue 2025-11-18 07:14:06.479: <-- 00000047 NOOP
Tue 2025-11-18 07:14:06.479: --> 00000047 OK NOOP completed
Tue 2025-11-18 07:14:06.479: <-- 00000048 SELECT Notizen
Tue 2025-11-18 07:14:06.480: --> * FLAGS (\Seen \Answered \Flagged \Deleted \Draft $Forwarded $MDNSent)
Tue 2025-11-18 07:14:06.480: --> * 0 EXISTS
Tue 2025-11-18 07:14:06.480: --> * 0 RECENT
Tue 2025-11-18 07:14:06.480: --> * OK [UIDVALIDITY 1763384659] UIDs valid
Tue 2025-11-18 07:14:06.480: --> * OK [UIDNEXT 1] Predicted next UID
Tue 2025-11-18 07:14:06.480: --> * OK [PERMANENTFLAGS (\Seen \Answered \Flagged \Deleted \Draft $Forwarded $MDNSent \*)] .
Tue 2025-11-18 07:14:06.480: --> 00000048 OK [READ-WRITE] SELECT completed
Tue 2025-11-18 07:14:06.480: <-- 00000049 GETQUOTA ""
Tue 2025-11-18 07:14:06.480: --> 00000049 NO GETQUOTA no such quota root
Tue 2025-11-18 07:14:06.483: <-- 0000004a MYRIGHTS Notizen
Tue 2025-11-18 07:14:06.483: --> * MYRIGHTS "Notizen" lrswipcda
Tue 2025-11-18 07:14:06.483: --> 0000004a OK MYRIGHTS completed
Tue 2025-11-18 07:14:06.487: <-- 0000004b NOOP
Tue 2025-11-18 07:14:06.487: --> 0000004b OK NOOP completed
Tue 2025-11-18 07:14:06.487: <-- 0000004c SELECT Postausgang
Tue 2025-11-18 07:14:06.487: --> * FLAGS (\Seen \Answered \Flagged \Deleted \Draft $Forwarded $MDNSent)
Tue 2025-11-18 07:14:06.487: --> * 0 EXISTS
Tue 2025-11-18 07:14:06.487: --> * 0 RECENT
Tue 2025-11-18 07:14:06.487: --> * OK [UIDVALIDITY 1763384659] UIDs valid
Tue 2025-11-18 07:14:06.487: --> * OK [UIDNEXT 1] Predicted next UID
Tue 2025-11-18 07:14:06.487: --> * OK [PERMANENTFLAGS (\Seen \Answered \Flagged \Deleted \Draft $Forwarded $MDNSent \*)] .
Tue 2025-11-18 07:14:06.487: --> 0000004c OK [READ-WRITE] SELECT completed
Tue 2025-11-18 07:14:06.488: <-- 0000004d GETQUOTA ""
Tue 2025-11-18 07:14:06.488: --> 0000004d NO GETQUOTA no such quota root
Tue 2025-11-18 07:14:06.489: <-- 0000004e MYRIGHTS Postausgang
Tue 2025-11-18 07:14:06.489: --> * MYRIGHTS "Postausgang" lrswipcda
Tue 2025-11-18 07:14:06.489: --> 0000004e OK MYRIGHTS completed
Tue 2025-11-18 07:14:06.492: <-- 0000004f NOOP
Tue 2025-11-18 07:14:06.492: --> 0000004f OK NOOP completed
Tue 2025-11-18 07:14:06.492: <-- 00000050 SELECT RSS-Feeds
Tue 2025-11-18 07:14:06.493: --> * FLAGS (\Seen \Answered \Flagged \Deleted \Draft $Forwarded $MDNSent)
Tue 2025-11-18 07:14:06.493: --> * 0 EXISTS
Tue 2025-11-18 07:14:06.493: --> * 0 RECENT
Tue 2025-11-18 07:14:06.493: --> * OK [UIDVALIDITY 1763384659] UIDs valid
Tue 2025-11-18 07:14:06.493: --> * OK [UIDNEXT 1] Predicted next UID
Tue 2025-11-18 07:14:06.493: --> * OK [PERMANENTFLAGS (\Seen \Answered \Flagged \Deleted \Draft $Forwarded $MDNSent \*)] .
Tue 2025-11-18 07:14:06.493: --> 00000050 OK [READ-WRITE] SELECT completed
Tue 2025-11-18 07:14:06.495: <-- 00000051 GETQUOTA ""
Tue 2025-11-18 07:14:06.495: --> 00000051 NO GETQUOTA no such quota root
Tue 2025-11-18 07:14:06.496: <-- 00000052 MYRIGHTS RSS-Feeds
Tue 2025-11-18 07:14:06.496: --> * MYRIGHTS "RSS-Feeds" lrswipcda
Tue 2025-11-18 07:14:06.496: --> 00000052 OK MYRIGHTS completed
Tue 2025-11-18 07:15:14.195: <-- 00000053 X-GWGETSETTINGS 2025-11-13T14:01:18.658Z
Tue 2025-11-18 07:15:14.195: --> 00000053 OK X-GWGETSETTINGS completed
Tue 2025-11-18 07:15:14.198: <-- 00000054 NOOP
Tue 2025-11-18 07:15:14.198: --> 00000054 OK NOOP completed
Tue 2025-11-18 07:15:14.199: <-- 00000055 SELECT "&ANY-ffentliche Ordner"
Tue 2025-11-18 07:15:14.199: --> 00000055 NO Mailbox does not exist
Tue 2025-11-18 07:15:14.199: <-- 00000056 LOGOUT
Tue 2025-11-18 07:15:14.199: --> * BYE IMAP engine signing off (no errors)
Tue 2025-11-18 07:15:14.199: --> 00000056 OK LOGOUT completed
Tue 2025-11-18 07:15:14.199: IMAP session complete, (Bytes in/out: 4357/6482)Till now no signaturfile in WC is being created.
Actually I tried:
- opening Account settings - Active Directory - Monitoring
- and just pressed the apply-button - not pressing "perform, full scan..."
- got my signature in Outlook
By the way ... connector log entries are not in chronological order...
Active Directory monitoring should not impact the client signature for a new user. When an authenticated client asks for the signature, it should be sent, regardless of how the account was created in MDaemon.
The "X-GWGETSETTINGS MDaemon signature" command is the client asking the server for the signature. It should do this at startup and approximately every 8 hours after that.
The log snippet provided that shows the "X-GWGETSETTINGS MDaemon signature" command being issued also shows us that the response to the command is 19399 bytes. So we know the signature is being sent back.
After you see the the client issue the "X-GWGETSETTINGS MDaemon signature" command, how long does it take before the signature appears in Outlook?
If you change the signature to be something very simple, does it accelerate the time frame for the signature to appear in Outlook? If it does, I suspect there is something in the signature that is causing the client side processing to be slow. Can you upload your signature files from the MDaemon\Domains\$DOMAINNAME\ directory so I can test with them?
Log entries are written to the log file when the session ends or if there are more lines in a session than its configured to save in memory they are written out to the file when the limit is reached. This means lines in the log file will not always be in chronological order.
You can make it easier to track sessions through the logs by enabling the option for Log ID string in mail session logs. (in Remote Administration it can be found at Logs | Log Settings | Settings.
Arron Caruth
to be honest, I didn't wait for an automatically refresh of the signaturefile, as I didn't know that 8-hours-refresh. It would be preferable, it that would be a configurable setting.
For my testing by creating a new signatur design I always closed and reopened Outlook, as then the signature file is actualized immediately. By the way, It didn't make a difference, wether to chose txt or html signature, both of them didn't come up.
And, to mention, if the signature-goes-to-outlook-process did work for the first time, changes to the signature at MDaemon are going to client (by restarting outlook...) are going without problems.
Surely I can give you my signaturefiles. As I cannot attach/upload to my post here, I would have to paste it inside the post but html is about 9 KB....
Should I paste?
Sorry, I forgot to provide the upload link. Please upload the files to https://mdaemon.sharefile.com/r-rc3922c1eed334d4dbf5e34f0bd04ccd6
Once you've uploaded the files, please let me know the name of the file you uploaded.
Arron Caruth
Did it, files are named EHF HTML and HBG HTML. text-versions are pretty unspectacular.
Please keep in mind, that if the signature-files arrived the new user's outlook for the first time, changes inside MDaemon will come without problems.
The head and body tags are not allowed in signatures. Once I removed head and body tags Outlook shows the signature immediately after creating a new account on my test machine.
Arron Caruth
Well, these files had been my files from external editor, with those tags. Inside MDaemon the BODY and HTML are not being presented.
And then, keep in mind, problem occurs just by adding a new user to MDaemon. Having that first step solved, any further changings (small adjustments inside signature and/or changing AD-Informations) will come through to client without problems.
In my testing, with the signature files provided, Outlook was slow to show the signature. After I removed the body and head tags, the signatures appeared in Outlook immediately when I created a new account and logged in with Outlook. Please try removing the body and head tags from your signatures. If you are still having issues after removing the tags, please upload the updated signature files from the MDaemon\Domains\$DOMAINNAME\ directory via, https://mdaemon.sharefile.com/r-rc3922c1eed334d4dbf5e34f0bd04ccd6 and I will test again with the new files.
Arron Caruth
