Thank you for following the steps so carefully and for the detailed screenshots. They made it possible to find the cause. My previous instructions left out a step, sorry about that.
Why the folders appear as "�" in Remote Administration
MDaemon stores public folder names on disk in the standard encoding that IMAP uses for folder names. This is how MDaemon's own translated folders, such as "Задачи" and "Контакты", are stored, which is why they display correctly. Remote Administration, webmail and mail clients all expect folder names in this form.
MDaemon uses the four [SpamFilter] folder names exactly as they are written in MDaemon.ini. When they are entered as Cyrillic text, the folders are created with names that Remote Administration cannot read. Your Windows settings are correct; the fix is to write the names in MDaemon.ini in the encoded form.
We have passed this on to our development team so that a future version handles non-English names for these folders automatically.
How to fix it
- Stop the MDaemon service.
- Open C:\MDaemon\App\MDaemon.ini.
- Under
[SpamFilter], replace the four lines with:
BayesianRootFolder=&BBEEMAQ5BDUEQQQ+BDIEQQQ6BD4ENQ- &BD4EMQRDBEcENQQ9BDgENQ-
BayesianHamFolderName=&BB0ENQ- &BEEEPwQwBDw-
BayesianSpamFolderName=&BCEEPwQwBDw-
SpamTrapFolderName=&BCEEPwQwBDw--&BDsEPgQyBEMESAQ6BDA-
- Under
[Directories], replace the two Bayesian folder lines with:
BayesianHamFolder=C:\MDaemon\Public Folders\&BBEEMAQ5BDUEQQQ+BDIEQQQ6BD4ENQ- &BD4EMQRDBEcENQQ9BDgENQ-.IMAP\&BB0ENQ- &BEEEPwQwBDw-.IMAP\
BayesianSpamFolder=C:\MDaemon\Public Folders\&BBEEMAQ5BDUEQQQ+BDIEQQQ6BD4ENQ- &BD4EMQRDBEcENQQ9BDgENQ-.IMAP\&BCEEPwQwBDw-.IMAP\
- Save the file as ANSI, as before.
Copy each value exactly. The spaces, the + signs and the double hyphen -- in the Spam Trap name are all part of the name.
- In
C:\MDaemon\Public Folders\, rename the existing folders. Renaming keeps the messages and access-control settings in them.
| Current name |
New name |
Байесовское обучение.IMAP |
&BBEEMAQ5BDUEQQQ+BDIEQQQ6BD4ENQ- &BD4EMQRDBEcENQQ9BDgENQ-.IMAP |
inside it: Не спам.IMAP |
&BB0ENQ- &BEEEPwQwBDw-.IMAP |
inside it: Спам.IMAP |
&BCEEPwQwBDw-.IMAP |
Спам-ловушка.IMAP |
&BCEEPwQwBDw--&BDsEPgQyBEMESAQ6BDA-.IMAP |
- Start MDaemon. In Remote Administration, open the Public Folder Manager. The folders should now show as "Байесовское обучение" (with "Не спам" and "Спам" inside it) and "Спам-ловушка". Bayesian learning and the Spam Trap use the renamed folders.
- If any Content Filter rules refer to these folders, update them to the new folder names. Users who subscribed to these folders in their mail client may need to refresh their folder list.
About the "Allowed Senders" folder
The name is not hard-coded. It comes from the WhiteListFolderName setting in C:\MDaemon\WorldClient\Domains.ini, under [Default:UserDefaults] (all domains) or [<your domain>:UserDefaults] (one domain).
We recommend leaving it as it is. The same setting also names every user's personal "Allowed Senders" folder, and changing it does not rename any folder that already exists. MDaemon starts using new, separate folders under the new name, so the senders already on the domain's and users' allowed lists would no longer be recognised. If you choose to rename the folder, at the server, you'll want to also rename the every user's person "Allowed Senders" folder.
If you have any questions, or anything doesn't look right after these steps, please send us a screenshot of the Public Folder Manager.
