What is AUTH X-MDWEBMAIL and how to disable it? | MDaemon Technologies Community Forum
  • Starting from version 23 MDaemon shows the X-MDWEBMAIL authorization type in the SMTP session:
    250-ETRN
    250-AUTH LOGIN CRAM-MD5 PLAIN X-MDWEBMAIL
    250-8BITMIME
    250-ENHANCEDSTATUSCODES
    250-PIPELINING
    250-CHUNKING
    250-STARTTLS
    What is this and how to turn it off?
    Thanks.
  • X-MDWEBMAIL is a custom authentication method for webmail to use when sending mail.  It is required in order for webmail to be able to send mail via an authenticated SMTP session.
    The X-MDWEBMAIL authentication option is only available for connections to MDaemon's own IP address and to local host.
    It cannot be disabled.
    Why are you wanting to disable it?
  • It's ok if the X-MDWEBMAIL authentication option is only available for connections to MDaemon's own IP address and to local host and not for external connections.
    Thank you.
