Dynamic Screening "Network Path Not Found"
I recently upgraded from v18.58 to the most recent version of MDaemon and now have an error when I try to configure Dynamic Screening.
"Unable to log on to the Dynamic Screening Service"
"The network path was not found"
I did a new test install on my laptop and it works fine so there is apparently a bug in the upgrade fro 18.58 to 23.52.
Anyone else ever see this?
Does this occur every time you open the dynamic screening dialog?
if you click Retry does it work or does the error pop up again?
Are there any errors in MDaemon's system, plugins, or dynamic screening logs?
Happens every time. The service is not running.
Error in Systems log:
Unable to log statistics data to database [C:\MDaemon\StatsDB\MDaemon-Statistics.db3], error: no such table: Statistics - 1
Dynamics Screening Log:
240307 000010116 G [00000000] Dynamic Screening (64bit) for MDaemon Messaging Server 23.5.2.6 Log file starting
240307 000010117 G [00000000] Build timestamp : Jan 30 2024 09:02:22
240307 000010117 G [00000000] 0x41350011 0x00000000
240307 000010117 G [00000000] 0x41350010 C:\MDaemon\Data\DynamicScreen.ini
240307 020601589 I [00000023] 0x41501114 Expiring Blocked IP:210.91.180.207 Comment:"Authentication Failures: 1"
Plugins log is empty aside from the startup header.
The error means that MDaemon wasn't able to communicate with the dynamic screening service via a named pipe. This can happen if you try to open the dynamic screening dialogs immediately after starting MDaemon and the dynamic screening service hasn't had time to complete its startup or if the dynamic screening service is so busy that it was unable to respond in the given time frame. In this case, simply retrying (sometimes multiple times) after a few sew seconds will have provided sufficient time for the service to complete its startup.
The error can also occur if something is preventing the dynamic screening service from running, in this case I would expect to see a crash dump created or an error logged.
In the MDaemon user interface, in the Servers section of the left window, is the Dynamic Screening service "started"?
If its not started, right click on it and click "Enable Dynamic Screening", does it change the state to "started" and does it stay at "started"?
If you restart the MDaemon service, are there any errors in MDaemon's plugins log? The only way I can think that the log could be empty is if you have logging by date enabled, and MDaemon has been running for multiple days. Dynamic Screening is loaded as a plugin so on startup, you should see a number of lines logged about the startup of dynamic screening, the first line to look for should look like this:
"Installing plug-in (DynScrn)"
If you are seeing this logged after restarting, please post the entire section from the plugins log.
If you are not seeing this logged, please check the MDaemon\plugins.at file for a [DynScrn] section, if it exists, please post the content of that section.
Are there any recently created dmp files in the MDaemon\Dumps directory? If there are, please zip and upload them to us for analysis using this link, https://mdaemon.sharefile.com/r-r77d4332c21ab4a28afe9e84ea94e2f3c. Let us know the name of the file that you uploaded.
Can you also open the MDaemon\Data\DynamicScreening.ini file and post the entire [System] section from the file?
@Arron I restarted MDaemon and see that Dynamic Screen shows no errors in the plugin log:
Fri 2024-03-08 10:55:17.684: I [33461D7B] Installing plug-in (DynScrn)
Fri 2024-03-08 10:55:17.684: I [33461D7B] C:\MDaemon\App\DynScrn.dll
Fri 2024-03-08 10:55:17.685: I [33461D7B] Dynamic Screening (64bit) for MDaemon Messaging Server, 23.5.2.6
Fri 2024-03-08 10:55:17.699: I [33461D7B] DynScrn::ConfigFuncName @00007FF8ECB64680
Fri 2024-03-08 10:55:17.699: I [33461D7B] DynScrn::HrMDPluginInitEx @00007FF8ECB629D0
Fri 2024-03-08 10:55:17.699: I [33461D7B] DynScrn::HrMDPluginServiceQueryState @00007FF8ECB68120
Fri 2024-03-08 10:55:17.699: I [33461D7B] DynScrn::HrMDPluginServiceQueryIcons @00007FF8ECB680D0
Fri 2024-03-08 10:55:17.699: I [33461D7B] DynScrn::HrMDPluginServiceControl @00007FF8ECB68280
Fri 2024-03-08 10:55:17.699: I [33461D7B] DynScrn::HrMDPluginServiceContextMenu @00007FF8ECB68550
Fri 2024-03-08 10:55:17.699: I [33461D7B] DynScrn::HrMDPluginServiceDblClk @00007FF8ECB664E0
Fri 2024-03-08 10:55:17.699: I [33461D7B] DynScrn::HrMDPluginGetLogfilePath @00007FF8ECB663E0
Fri 2024-03-08 10:55:17.699: I [33461D7B] DynScrn::HrMDPluginMTAPreProcess @00007FF8ECB675B0
Fri 2024-03-08 10:55:17.699: I [33461D7B] DynScrn::MenuItem::&Options/Customize @00007FF8ECB64680
Fri 2024-03-08 10:55:17.699: I [33461D7B] DynScrn::MenuItem::&View/Analyze Log File @00007FF8ECB65380
Fri 2024-03-08 10:55:17.699: I [33461D7B] DynScrn::MenuItem::&Allow List Editor @00007FF8ECB63500
Fri 2024-03-08 10:55:17.699: I [33461D7B] DynScrn::MenuItem::&Block List Editor @00007FF8ECB63670
Fri 2024-03-08 10:55:17.700: I [33461D7B] DynScrn::MenuItem::Domain &NAT Exemption Editor @00007FF8ECB63950
Fri 2024-03-08 10:55:17.700: I [33461D7B] Initializing DynScrn plug-in
Fri 2024-03-08 10:55:17.700: I [33461D7B] Dynamic Screening (64bit) for MDaemon Messaging Server
Fri 2024-03-08 10:55:17.702: I [33461D7B] 0x00000000 The operation completed successfully.
Fri 2024-03-08 10:55:17.703: I [33461D7B] Creating core object
Fri 2024-03-08 10:55:17.727: I [33461D7B] Creating service object
Fri 2024-03-08 10:55:17.728: I [33461D7B] 0x00000000 The operation completed successfully.
Fri 2024-03-08 10:55:17.728: I [33461D7B] DynScrn plug-in loaded in slot 1The Dynamic Screen log shows it is running, expiring timed out IPs etc. The network path error persists when I try to make any configuration changes.
The Dump folder does not have anything from the restart today.
Also, if I reinstall v18.x Dynamic Screen config works fine.
From DynamicScreen.ini:
[AD]
UseAuthFailures=Yes
UseBlackList=Yes
UseGeoBlock=No
UseWhiteList=Yes[API]
UseAuthFailures=Yes
UseBlackList=Yes
UseGeoBlock=No
UseWhiteList=Yes[AS]
UseAuthFailures=Yes
UseBlackList=Yes
UseGeoBlock=No
UseWhiteList=Yes[AuthFail]
AutoThaw=Yes
BlockThreshold=1
BlockTimespan=60
EnableBlocking=Yes
FreezeAccount=No
FreezeThreshold=10
FreezeTimeout=30
FreezeTimespan=30
IgnoreDupePWs=Yes
IgnoreOnlyValid=No
IP4EnableAggregation=Yes
IP6EnableAggregation=Yes
IPV4AggBits=24
IPV6AggBits=56
ThawByEmail=Yes[BlackList]
ExpMinutes=60
NeverExpire=No
RepeatOffense02Penalty=4320
RepeatOffense03Penalty=20160
RepeatOffense04Penalty=4147200[Cluster]
FailoverTimeout=60[DAV]
UseAuthFailures=No
UseBlackList=No
UseGeoBlock=No
UseWhiteList=No[IMAP]
UseAuthFailures=Yes
UseBlackList=Yes
UseGeoBlock=No
UseWhiteList=Yes[IMAPS]
UseAuthFailures=Yes
UseBlackList=Yes
UseGeoBlock=Yes
UseWhiteList=Yes[Logs]
AllBlacklistHits=Yes
AllGeoBlockHits=Yes
AllTrustedIPlistHits=Yes
AllWhitelistHits=Yes
AlwaysLogLocation=No
AuthFail=Yes
AuthFailAtStartup=No
AuthSuccess=Yes
BlackListAtStartup=No
ConnectionsAllowed=Yes
ConnectionsRefused=Yes
DebuggerMinEntryType=1
DetectedChanges=Yes
HasDeviceIdEntries=No
HasDeviceTypeEntries=No
HasOperationEntries=No
HasUserEntries=No
LatestLogFile=C:\MDaemon\Logs\DynScrn-2024-02-27.log
LogHasDeviceIdEntries=No
LogHasDeviceTypeEntries=No
LogHasOperationEntries=No
LogHasUserEntries=No
LogLevel=1
LogName=DynScrn
SummaryTimeFrame=2
WhiteListAtStartup=No[Logs:DebugToInfo]
;ie. 0x40000000=Yes
;Over-ridden by Logs:IgnoreEntry
;Over-ridden by Logs:IgnoreSession
!Exists=1
0x00000000=Yes
0x41500100=Yes
0x41500102=Yes
0x41500104=Yes
0x41500106=Yes
0x41500108=Yes
0x4150010A=Yes
0x4150010C=Yes
0x4150010E=Yes
0x41500112=Yes
0x41500114=Yes
0x41500116=Yes
0x41500118=Yes
0x4150011A=Yes
0x4150011C=Yes
0x4150011F=Yes
0x41500F04=Yes
0x41500F08=Yes
0x41500F0A=Yes
0x41500F0C=Yes
0x41500F10=Yes
0x41500F14=Yes
0x41500F18=Yes
0x41500F1C=Yes
0x41500F20=Yes
0x41500F24=Yes
0x41500F28=Yes
0x41500F2C=Yes
0x41500F30=Yes
0x41500F34=Yes
0x41501000=Yes
0x41501004=Yes
0x4150100C=Yes
0x41501010=Yes
0x41501014=Yes
0x41501018=Yes
0x4150101C=Yes
0x41501020=Yes
0x41501024=Yes
0x41501028=Yes
0x4150102A=Yes
0x41501104=Yes
0x41501108=Yes
0x41501109=Yes
0x4150110A=Yes
0x4150110C=Yes
0x41501114=Yes
0x41501118=Yes
0x4150111C=Yes
0x41501180=Yes
0x41501181=Yes
0x41501182=Yes
0x41501183=Yes
0x41501184=Yes
0x41501185=Yes
0x41501200=Yes
0x41501201=Yes
0x41501202=Yes
0x41501203=Yes
0x41501204=Yes
0x41501205=Yes
0x41501206=Yes
0x41501207=Yes
0x41501208=Yes
0x41501209=Yes
0x4150120A=Yes
0x41501220=Yes
0x41501300=Yes
0x41501304=Yes
0x41501308=Yes
0x4150130C=Yes
0x41501310=Yes
0x41501314=Yes
0x41501400=Yes
0x41501404=Yes
0x41501500=Yes
0x41501508=Yes
0x41502000=Yes
0x41502010=Yes
0x41502014=Yes
0x41502018=Yes
0x4150201C=Yes
0x41502020=Yes
0x41502024=Yes
0x41502028=Yes
0x4150202C=Yes
0x41502030=Yes
0x41502034=Yes
0x41502038=Yes
0x4150203C=Yes
0x41502040=Yes
0x41502044=Yes
0x41502048=Yes
0x4150204C=Yes
0x41502050=Yes
0x41502054=Yes
0x41502058=Yes
0x4150205C=Yes
0x41502060=Yes
0x41502064=Yes
0x41502068=Yes
0x4150206C=Yes
0x41502070=Yes
0x41502074=Yes
0x415022C8=Yes
0x415022CC=Yes
0x41502400=Yes
0x41502401=Yes
0x41502402=Yes
0x41502403=Yes
0x41502404=Yes
0x41502405=Yes
0x41502406=Yes
0x41502407=Yes
0x41502408=Yes
0x41502409=Yes
0x4150240A=Yes
0x4150240B=Yes
0x4150240C=Yes
0x4150240D=Yes
0x41502620=Yes
0x41502621=Yes
0x41502622=Yes
0x41502623=Yes
0x41502624=Yes
0x41502625=Yes
0x41502626=Yes
0x41502627=Yes
0x41502628=Yes
0x41502629=Yes
0x4150262A=Yes
0x4150262B=Yes
0x4150262C=Yes
0x4150262D=Yes
0x4150262E=Yes
0x4150262F=Yes
0x41502640=Yes
0x41502641=Yes
0x41502642=Yes
0x41502643=Yes
0x41502644=Yes
0x41502645=Yes
0x41502646=Yes
0x41502647=Yes
0x41502648=Yes
0x41502649=Yes
0x4150264A=Yes
0x4150264B=Yes
0x4150264C=Yes
0x4150264D=Yes
0x4150264E=Yes
0x4150264F=Yes
0x41502810=Yes
0x41502811=Yes
0x41502812=Yes
0x41502813=Yes
0x41502814=Yes
0x41502815=Yes
0x41502816=Yes
0x41502817=Yes
0x41502818=Yes
0x41502819=Yes
0x4150281A=Yes
0x4150281B=Yes
0x4150281C=Yes
0x4150281D=Yes
0x4150281E=Yes
0x4150281F=Yes
0x41502A00=Yes
0x41502A01=Yes
0x41502A03=Yes
0x41502A04=Yes
0x41502A05=Yes
0x41502A06=Yes
0x41502A07=Yes
0x41502A08=Yes
0x41502A09=Yes
0x41502A0A=Yes
0x41502A0B=Yes
0x41502A0C=Yes
0x41502A0D=Yes
0x41502A0E=Yes
0x41502A0F=Yes
0x41502A12=Yes
0x41502C00=Yes
0x41502C01=Yes
0x41502C02=Yes
0x41502C03=Yes
0x41502C04=Yes
0x41502C05=Yes
0x41502C06=Yes
0x41502C07=Yes
0x41502C08=Yes
0x41502C09=Yes
0x41502C0A=Yes
0x41502C0B=Yes
0x41502C0C=Yes
0x41502C0D=Yes
0x41502C0E=Yes
0x41502C0F=Yes
0x41502D00=Yes
0x41502D01=Yes
0x41502D02=Yes
0x41502D03=Yes
0x41502D04=Yes
0x41502D05=Yes
0x41502D06=Yes
0x41502D07=Yes
0x41502D08=Yes
0x41502D09=Yes
0x41502D0A=Yes
0x41502D0B=Yes
0x41502D0C=Yes
0x41502D0D=Yes
0x41502D0E=Yes
0x41502D0F=Yes
0x41502D20=Yes
0x41502D22=Yes
0x41502D24=Yes
0x41503000=Yes
0x41503001=Yes
0x41503002=Yes
0x41503003=Yes
0x41503004=Yes
0x41503005=Yes
0x41503006=Yes
0x41503007=Yes
0x41503008=Yes
0x41503009=Yes
0x4150300A=Yes
0x4150300B=Yes
0x4150300C=Yes
0x4150300D=Yes
0x4150300E=Yes
0x4150300F=Yes
0x41503010=Yes
0x41503014=Yes
0x41504000=Yes
0x41504001=Yes
0x41504002=Yes
0x41504003=Yes
0x41504004=Yes
0x41504005=Yes
0x41504006=Yes
0x41504007=Yes
0x41504008=Yes
0x41504009=Yes
0x4150400A=Yes
0x4150400B=Yes
0x4150400C=Yes
0x4150400D=Yes
0x4150400E=Yes
0x41504010=Yes
0x41504011=Yes
0x41504012=Yes
0x41504013=Yes
0x41504014=Yes
0x41504015=Yes
0x41504016=Yes
0x41504017=Yes
0x41504018=Yes
0x41504019=Yes
0x4150401A=Yes
0x4150401B=Yes
0x4150401C=Yes
0x4150401D=Yes
0x4150401E=Yes
0x4150401F=Yes
0x41504021=Yes
0x41504022=Yes
0x41504023=Yes
0x41504024=Yes
0x41504025=Yes
0x41504026=Yes
0x41504027=Yes
0x41504028=Yes
0x41504030=Yes
0x41504031=Yes
0x41504032=Yes
0x41504033=Yes
0x41504034=Yes
0x41504035=Yes
0x41504036=Yes
0x41504037=Yes
0x41504038=Yes
0x41504039=Yes
0x4150403A=Yes
0x4150403B=Yes
0x4150403C=Yes
0x4150403D=Yes
0x4150403E=Yes
0x4150403F=Yes
0x415040C0=Yes
0x415040C1=Yes
0x415040C2=Yes
0x415040C3=Yes
0x415040C4=Yes
0x415040C5=Yes
0x415040C6=Yes
0x415040C7=Yes
0x415040C8=Yes
0x415040C9=Yes
0x415040CA=Yes
0x415040CB=Yes
0x415040CC=Yes
0x415040CD=Yes
0x415040CE=Yes
0x415040CF=Yes
0x415040E0=Yes
0x415040E1=Yes
0x415040E2=Yes
0x415040E3=Yes
0x415040E4=Yes
0x415040E5=Yes
0x415040E6=Yes
0x415040E7=Yes
0x415040E8=Yes
0x415040E9=Yes
0x415040EA=Yes
0x415040EB=Yes
0x415040EC=Yes
0x415040ED=Yes
0x415040EE=Yes
0x415040EF=Yes
0x41504130=Yes
0x41504131=Yes
0x41504132=Yes
0x41504133=Yes
0x41504134=Yes
0x41504135=Yes
0x41504136=Yes
0x41504137=Yes
0x41504138=Yes
0x41504139=Yes
0x4150413A=Yes
0x4150413B=Yes
0x4150413C=Yes
0x4150413D=Yes
0x4150413E=Yes
0x4150413F=Yes
0x41504150=Yes
0x41504151=Yes
0x41504152=Yes
0x41504153=Yes
0x41504154=Yes
0x41504155=Yes
0x41504156=Yes
0x41504157=Yes
0x41504158=Yes
0x41504159=Yes
0x4150415A=Yes
0x4150415B=Yes
0x4150415C=Yes
0x4150415D=Yes
0x4150415E=Yes
0x4150415F=Yes
0x415041A0=Yes
0x415041A1=Yes
0x415041A2=Yes
0x415041A3=Yes
0x415041A4=Yes
0x415041A5=Yes
0x415041A6=Yes
0x415041A7=Yes
0x415041A8=Yes
0x415041A9=Yes
0x415041AA=Yes
0x415041AB=Yes
0x415041AC=Yes
0x415041AD=Yes
0x415041AE=Yes
0x415041AF=Yes
0x415041C0=Yes
0x415041C1=Yes
0x415041C2=Yes
0x415041C3=Yes
0x415041C4=Yes
0x415041C5=Yes
0x415041C6=Yes
0x415041C7=Yes
0x415041C8=Yes
0x415041C9=Yes
0x415041CA=Yes
0x415041CB=Yes
0x415041CC=Yes
0x415041CD=Yes
0x415041CE=Yes
0x415041CF=Yes
0x41504E00=Yes
0x41505010=Yes
0x41505011=Yes
0x41505012=Yes
0x41505013=Yes
0x41505014=Yes
0x41505015=Yes
0x41505016=Yes
0x41505017=Yes
0x41505018=Yes
0x41505019=Yes
0x4150501A=Yes
0x4150501B=Yes
0x4150501C=Yes
0x4150501D=Yes
0x4150501E=Yes
0x4150501F=Yes
0x41505030=Yes
0x41505031=Yes
0x41505032=Yes
0x41505033=Yes
0x41505034=Yes
0x41505035=Yes
0x41505036=Yes
0x41505037=Yes
0x41505038=Yes
0x41505039=Yes
0x4150503A=Yes
0x4150503B=Yes
0x4150503C=Yes
0x4150503D=Yes
0x4150503E=Yes
0x4150503F=Yes
0x41505130=Yes
0x41505131=Yes
0x41505132=Yes
0x41505133=Yes
0x41505134=Yes
0x41505135=Yes
0x41505136=Yes
0x41505137=Yes
0x41505138=Yes
0x41505139=Yes
0x4150513A=Yes
0x4150513B=Yes
0x4150513C=Yes
0x4150513D=Yes
0x4150513E=Yes
0x4150513F=Yes
0x41505150=Yes
0x41505151=Yes
0x41505152=Yes
0x41505153=Yes
0x41505154=Yes
0x41505155=Yes
0x41505156=Yes
0x41505157=Yes
0x41505158=Yes
0x41505159=Yes
0x4150515A=Yes
0x4150515B=Yes
0x4150515C=Yes
0x4150515D=Yes
0x4150515E=Yes
0x4150515F=Yes
0x41506010=Yes
0x41506011=Yes
0x41506012=Yes
0x41506013=Yes
0x41506014=Yes
0x41506015=Yes
0x41506016=Yes
0x41506017=Yes
0x41506018=Yes
0x41506019=Yes
0x4150601A=Yes
0x4150601B=Yes
0x4150601C=Yes
0x4150601D=Yes
0x4150601E=Yes
0x4150601F=Yes
0x41506030=Yes
0x41506031=Yes
0x41506032=Yes
0x41506033=Yes
0x41506034=Yes
0x41506035=Yes
0x41506036=Yes
0x41506037=Yes
0x41506038=Yes
0x41506039=Yes
0x4150603A=Yes
0x4150603B=Yes
0x4150603C=Yes
0x4150603D=Yes
0x4150603E=Yes
0x4150603F=Yes
0x415060C0=Yes
0x415060C1=Yes
0x415060C2=Yes
0x415060C3=Yes
0x415060C4=Yes
0x415060C5=Yes
0x415060C6=Yes
0x415060C7=Yes
0x415060C8=Yes
0x415060C9=Yes
0x415060CA=Yes
0x415060CB=Yes
0x415060CC=Yes
0x415060CD=Yes
0x415060CE=Yes
0x415060CF=Yes
0x415060E0=Yes
0x415060E1=Yes
0x415060E2=Yes
0x415060E3=Yes
0x415060E4=Yes
0x415060E5=Yes
0x415060E6=Yes
0x415060E7=Yes
0x415060E8=Yes
0x415060E9=Yes
0x415060EA=Yes
0x415060EB=Yes
0x415060EC=Yes
0x415060ED=Yes
0x415060EE=Yes
0x415060EF=Yes
0x41506130=Yes
0x41506131=Yes
0x41506132=Yes
0x41506133=Yes
0x41506134=Yes
0x41506135=Yes
0x41506136=Yes
0x41506137=Yes
0x41506138=Yes
0x41506139=Yes
0x4150613A=Yes
0x4150613B=Yes
0x4150613C=Yes
0x4150613D=Yes
0x4150613E=Yes
0x4150613F=Yes
0x41506150=Yes
0x41506151=Yes
0x41506152=Yes
0x41506153=Yes
0x41506154=Yes
0x41506155=Yes
0x41506156=Yes
0x41506157=Yes
0x41506158=Yes
0x41506159=Yes
0x4150615A=Yes
0x4150615B=Yes
0x4150615C=Yes
0x4150615D=Yes
0x4150615E=Yes
0x4150615F=Yes
0x41507010=Yes
0x41507011=Yes
0x41507012=Yes
0x41507013=Yes
0x41507014=Yes
0x41507015=Yes
0x41507016=Yes
0x41507017=Yes
0x41507018=Yes
0x41507019=Yes
0x4150701A=Yes
0x4150701B=Yes
0x4150701C=Yes
0x4150701D=Yes
0x4150701E=Yes
0x4150701F=Yes
0x41507030=Yes
0x41507031=Yes
0x41507032=Yes
0x41507033=Yes
0x41507034=Yes
0x41507035=Yes
0x41507036=Yes
0x41507037=Yes
0x41507038=Yes
0x41507039=Yes
0x4150703A=Yes
0x4150703B=Yes
0x4150703C=Yes
0x4150703D=Yes
0x4150703E=Yes
0x4150703F=Yes
0x41507130=Yes
0x41507131=Yes
0x41507132=Yes
0x41507133=Yes
0x41507134=Yes
0x41507135=Yes
0x41507136=Yes
0x41507137=Yes
0x41507138=Yes
0x41507139=Yes
0x4150713A=Yes
0x4150713B=Yes
0x4150713C=Yes
0x4150713D=Yes
0x4150713E=Yes
0x4150713F=Yes
0x41507150=Yes
0x41507151=Yes
0x41507152=Yes
0x41507153=Yes
0x41507154=Yes
0x41507155=Yes
0x41507156=Yes
0x41507157=Yes
0x41507158=Yes
0x41507159=Yes
0x4150715A=Yes
0x4150715B=Yes
0x4150715C=Yes
0x4150715D=Yes
0x4150715E=Yes
0x4150715F=Yes
0x4150A000=Yes
0x4150A001=Yes
0x4150A002=Yes
0x4150A003=Yes
0x4150A004=Yes
0x4150A005=Yes
0x4150A006=Yes
0x4150A007=Yes
0x4150A008=Yes
0x4150A009=Yes
0x4150A00A=Yes
0x4150A00B=Yes
0x4150A00C=Yes
0x4150A00D=Yes
0x4150A00E=Yes
0x4150A00F=Yes[Logs:DebugToWarning]
!Exists=1
0x00000000=Yes
0x41504001=Yes[Logs:IgnoreEntry]
;ie. 0x80000000=Yes
!Exists=1
0x41502A24=Yes
0x41502AC0=Yes[Logs:IgnoreSession]
;ie. 00000000A=Yes
!Exists=1[Logs:WarningToInfo]
;ie. 0x80000000=Yes
!Exists=1[MDDP]
UseAuthFailures=Yes
UseBlackList=Yes
UseGeoBlock=No
UseWhiteList=Yes[MNGR]
UseAuthFailures=Yes
UseBlackList=Yes
UseGeoBlock=No
UseWhiteList=Yes[Notify]
AuthFailureThreshold=1
DefaultAddress=
IncludeIPHistory=No
OnAuthFailures=Yes
OnAuthFailuresDA=No
OnAuthFailuresDP=No
OnAuthFailuresGA=No
OnAuthFailuresGP=Yes
OnAuthFailuresUser=No
OnAutoThaw=Yes
OnExpireBlack=No
OnExpireGA=No
OnExpireGP=Yes
OnExpireWhite=No
OnFreeze=Yes
OnFreezeDA=No
OnFreezeDP=No
OnFreezeGA=No
OnFreezeGP=Yes
OnFreezeUser=No
OnIPBlock=No
OnIPBlockGA=No
OnIPBlockGP=Yes
OnSemaphoreBlock=No
UseGMT=No[NotifyCSS]
body={ font-family: Tahoma, Arial, Helvetica, sans-serif; background-color: #F9F9F9; font-size: 10pt; }
caption={ font-family: Consolas, 'Courier New', monospace; font-weight: 700; }
div={ font-family: Tahoma, Arial, Helvetica, sans-serif; background-color: #F9F9F9; font-size: 10pt; }
div.copyright={ font-size: 8pt; }
div.footnote={ font-size: 9pt; font-weight: 400; font-style: italic; }
div.header={ font-size: 10pt; font-weight: 700; }
div.replyfooter={ font-size: 10pt; font-weight: 700; color: red; }
div.trailer={ font-size: 10pt; font-weight: 400; }
table={ font-family: Consolas, 'Courier New', monospace; background-color: #F9F9F9; font-size: 10pt; border-style: inset; width:95%; border-width: thin; table-layout: auto; border-collapse: separate; border-spacing: 2px; empty-cells: show; caption-side: top; }
tbody={ font-family: Consolas, 'Courier New', monospace; background-color: #F0F0F0; }
td={ font-family: Consolas, 'Courier New', monospace; background-color: #F4F4F4; }
th={ font-family: Consolas, 'Courier New', monospace; background-color: #E0E0E0; }
thead={ font-family: Consolas, 'Courier New', monospace; background-color: #E4E4E4; }[Options]
BlockLogonPolicyViolations=No[POP]
UseAuthFailures=Yes
UseBlackList=Yes
UseGeoBlock=No
UseWhiteList=Yes[POPS]
UseAuthFailures=Yes
UseBlackList=Yes
UseGeoBlock=Yes
UseWhiteList=Yes[RA]
UseAuthFailures=Yes
UseBlackList=Yes
UseGeoBlock=No
UseWhiteList=Yes[SMTP]
UseAuthFailures=Yes
UseBlackList=Yes
UseGeoBlock=No
UseWhiteList=Yes[SMTPS]
UseAuthFailures=Yes
UseBlackList=Yes
UseGeoBlock=Yes
UseWhiteList=Yes[Support]
0xC135FE00=3
0xC135FE01=3
0xC135FE04=3
0xC135FE08=3
0xC135FE0D=3
0xC135FE10=3
0xC135FE14=3
0xC135FE18=3
0xC135FE1C=3
0xC135FE20=3
0xC135FE24=3
0xC135FE28=3
0xC135FE2C=3
0xC135FE30=3
0xC135FE34=3
0xC135FE38=3
0xC135FE3C=3
0xC135FE40=3
0xC135FE44=3
0xC135FE48=3
0xC135FE4C=3
0xC135FE50=3
0xC135FE54=3
0xC135FE58=3
0xC135FE5C=3
0xC135FE60=3
0xC135FE68=3
0xC135FEF0=3
0xC135FFFF=3
DumpDataSegs=Yes
DumpPrefix=DynScrn
EnableDumps=No[System]
AdvancedUI=Yes
Enable=Yes
EnableAuthFailures=Yes
EnableBlackList=Yes
EnableWhiteList=Yes
IOInterval=15
MDPGPExempt=No
Paused=No
UseGeoBlock=No[WC]
UseAuthFailures=Yes
UseBlackList=Yes
UseGeoBlock=No
UseWhiteList=Yes[XMPP]
UseAuthFailures=Yes
UseBlackList=Yes
UseGeoBlock=No
UseWhiteList=Yes
Please zip and upload your entire plugin and dynamic screening log files for today to https://mdaemon.sharefile.com/r-r77d4332c21ab4a28afe9e84ea94e2f3c.
Please let me know the name of the file that you upload.
File Stennett.zip uploaded.
I'm not seeing the file, did the upload complete? Can you try it again?
I uploaded it again.
Thank you for uploading the file again.
What user is the MDaemon service configured to run as? Is it localy system or someother user?
If the service is not set to run as local system, do you have the same issue with it running as local system?
When you are starting the MDaemon UI session, which user is it being started as? Is the user a administrator on the local machine?
Also, can you export the following key from your registry and send me the file?
HKEY_LOCAL_MACHINE\SOFTWARE\Alt-N Technologies\MDaemon\DynamicScreening\Configuration
@Arron File uploaded as Stennett.reg
@Arron The service is set to local system.
@Arron The UI is started under the adminnstrator account.
- 1 / 2
- 2
