Global setting for "view sender by"
Is there a way set "view sender by" to email address instead of name globally?
currently it defaults to view by name but would like to show all email address so people could actually see the domain its coming from.
Thank you.
0 likes 0 likes
3
Posts74
Views
Edit the MDaemon\WorldClient\domains.ini file and set
ListShowByAddress=1
If you add it in the [Default:UserDefaults] section, it will set the default value for users. This will allow the user to still change the value and if the user has set a specific value already, they will continue using that value.
If you add it in the [Default:UserOverrides] section, it will force all users to the value set. They will not be able to change it.
Once you have it set how you want it, Save the file and restart webmail.
Arron Caruth0 likes 0 likes
Thank you so much!!!
0 likes 0 likes
Search
Latest topics
Latest posts
Forum statistics
- Page views (24h):
- 1,648
- Page views (30d):
- 10,998
- Topics:
- 601
- 3,741
- Members:
- 747
